[Geomoose-users] Geomoose-users Digest, Vol 47, Issue 13
Clinton Olsen clinton at co.emery.ut.us
Thu Aug 11 16:04:30 EDT 2011
I included the defined projection that was in mapbook.xml into the map level
of the mapbook file.  The porjection in mapbok.xml is epsg:2281.  Tried to
identify and nothing was changed.  Still has the same result.
The precincts layer shows up properly on the geomoose wep app.  I can see it
fine, and it shows up with the other layers.  Let me know if I can answer
anything else.
-----Original Message-----
Sent: Thursday, August 11, 2011 11:27 AM
To: Clinton Olsen; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 47, Issue 13
Set the projection object at the map level to match the same projection as
you've configured in the mapbook.
Are the precincts mapping properly?
  _____
To: geomoose-users at lists.sourceforge.net
Sent: Thursday, August 11, 2011 11:03 AM
Dan,
I added projection to the mapfile, but I still get the same result. Below
are the contents of the mapfile.  Thanks for your help so far.
MAP
NAME            'PRECINCTS'
SIZE            800 650
STATUS        ON
EXTENT        1426801 6519737 2267577 7175357
UNITS            FEET
FONTSET        '../fonts/fontset.list'
SYMBOLSET        '../symbols/symbol.sym'
TRANSPARENT        TRUE
IMAGETYPE        PNG
QUERYMAP
    STATUS    ON
    STYLE        SELECTED
END
LEGEND
    STATUS     ON
END
LAYER
    NAME            "PRECINCTS"
    DATA            "./PRECINCTS.shp"
    STATUS        DEFAULT
    TYPE            POLYGON
    TOLERANCE        3
    CLASSITEM        "NAME"
    LABELITEM        "NAME"
    PROJECTION
            "init=esri:102743"
    END
    CLASS
        EXPRESSION 'Orangeville #5.09'
        NAME    'Orangeville #5.09'
            STYLE
                COLOR 255 102 0
                OUTLINECOLOR 0 0 255
                SIZE 2
            END
          LABEL
                    TYPE TRUETYPE
                    FONT vera_sans-bold
                    SIZE 8
                    ANTIALIAS true
                    COLOR 153 0 153
                    OUTLINECOLOR 254 254 254
                    BUFFER 3
                    MINFEATURESIZE auto
                    PARTIALS FALSE
                    POSITION ul
            END
    END
    METADATA
        'identify_record' 'identify_precincts.html'
    END
    TOLERANCE 0
END
END
From: geomoose-users-request at lists.sourceforge.net
[mailto:geomoose-users-request at lists.sourceforge.net]
Sent: Thursday, August 11, 2011 9:22 AM
Subject: Geomoose-users Digest, Vol 47, Issue 13
Send Geomoose-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    https://lists.sourceforge.net/lists/listinfo/geomoose-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    geomoose-users-owner at lists.sourceforge.net
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Geomoose-users digest..."
Today's Topics:
  1. Re: Identify Feture not working on layers (Dan Little)
  2. Re: Identify Feture not working on layers (Clinton Olsen)
Message: 1
Date: Thu, 11 Aug 2011 08:15:13 -0700 (PDT)
Subject: Re: [Geomoose-users] Identify Feture not working on layers
To: Clinton Olsen <clinton at co.emery.ut.us>,    'Brian Fischer'
    <bfischer at houstoneng.com>,
"geomoose-users at lists.sourceforge.net"
    <geomoose-users at lists.sourceforge.net>
Message-ID:
    <1313075713.13516.YahooMailNeo at web161212.mail.bf1.yahoo.com>
Content-Type: text/plain; charset="iso-8859-1"
I'm thinking you'll need to specify the projection in the layer entry.
LAYER?
?PROJECTION
? ?'init=esri:102743'
?END
END
>________________________________
>From: Clinton Olsen <clinton at co.emery.ut.us>
>To: 'Dan Little' <danlittle at yahoo.com>; 'Brian Fischer'
><bfischer at houstoneng.com>; geomoose-users at lists.sourceforge.net
>Sent: Thursday, August 11, 2011 9:58 AM
>Subject: RE: [Geomoose-users] Identify Feture not working on layers
>Message
>Dan Little,
>Here are the contents of the identify tool using firebug and firefox.I hope
this is what you wanted to look at.
><results><script/><html><![CDATA[<!-- MapServer Template --> Detailed
information for the area you clicked on the map... <table border="0"> <tr>
<td colspan="2"><b><u>Ground Coordinates</u></b> <br> <b>X: </b>1751465 <br>
<b>Y: </b>6901114.5</td> </tr> <tr> <td>&nbsp;</td> <td>&nbsp;</td> </tr>
</table> <table border="0" cellpadding="1" cellspacing="2"> <!-- MapServer
Template --> <tr> <td colspan="2">Disclaimer: This information is being
distributed as demonstation data only.  You shouldnot use the data for any
other purposes.</td> </tr> </table> ]]></html></results>
>Brian Fischer,
>The projection in my mapbook.xml is EPSG:2281.  The ESRI projection I am
using for the shape files is ESRI:102743.
>Not sure what the EPSG equivalent is for that ESRI projection.  Maybe that
is why when I use the print feature it only prints a blank page.
>>From: Dan Little  [mailto:danlittle at yahoo.com]
>>Sent: Wednesday, August 10, 2011 7:43  PM
>>To: neslonotnilc;  geomoose-users at lists.sourceforge.net
>>Do you happen to have Firefox with Firebug installed?
>>I'd like to see the actual contents being sent back. ?I'm not  100%
>>sure what's going wrong yet...
>>> From: neslonotnilc  <clinton at co.emery.ut.us>
>>>Sent: Wednesday, August 10, 2011 2:45  PM
>>>Subject: [Geomoose-users] Identify Feture not working on  layers
>>>Hi,
>>>I am doing an upgrade from a 1.x geomoose
    install.? I have my esri layers
>>>showing up in geomoose, but when I
    try to do an identify on the layers I
>>>only return the default X and Y
    coordinate template.? I have looked through
>>>the wiki, the online
    forum, and online searches and tried to make my data
>>>fit with what is
    presented but I still can't get identify to work.? Also a
>>>wierd
    thing that happens when I try to do a identify I get 1kb PNG files
>>>that
    populate the folder that contains the layer mapbook file.? Please
    point
>>>me in the right direction.? The identify tool is great for
    what we are
>>>trying to do with Geomoose, but if it is temperamental then
    maybe I should
>>>stick with the working 1.x install.? Only problem
    with that is some of the
>>>features don't work in the newer browsers.?
    Thanks.? Clinton
>>>This is what I have in the mapbook.xml
    file:
>>><service name="identify" title="Identify"
    display="false">
>>><url>php/identify.php</url>
>>><step
    type="spatial" name="shape" line="false"
    polygon="false"
>>>jump-start="true" default="point">
>>><input
    type="visiblelayers"
    name="layers"/>
>>></step>
>>></service>
>>>__________
>>><tool
    name="identify" title="Identify" type="service"
    service="identify"/>
>>>__________
>>>In the layer mapbook I
    have:
>>>LAYER
>>>NAME??? ???
    ??? "PRECINCTS"???
    DATA??? ??? ???
    "./PRECINCTS.shp"
>>>??? STATUS???
    ??? DEFAULT
>>>??? TYPE???
    ??? ??? POLYGON
    TOLERANCE??? ??? 3
    CLASSITEM??? ??? "NAME"
    LABELITEM??? ??? "NAME"
>>>??? CLASS
    ??? EXPRESSION 'Orangeville #5.09'
    ??? NAME??? 'Orangeville
    #5.09'
    STYLE
    ??? COLOR 255 102 0
    ??? ??? OUTLINECOLOR 0 0
    255
    ??? SIZE 2
    ??? END
    LABEL
    ??? TYPE TRUETYPE
    ? ??? ??? FONT
    vera_sans-bold
    ??? ??? SIZE 8
    ? ? ? ??? ??? ANTIALIAS
    true
    ??? COLOR 153 0 153
    ? ? ??? ??? OUTLINECOLOR 254 254
    254
    ??? BUFFER 3
    ? ??? ??? MINFEATURESIZE
    auto
    ??? PARTIALS FALSE
    ? ??? ??? POSITION ul
    ??? ? ? ? END
    END
>>>METADATA
    'identify_record'
>>>END
>>>END
>>>View this
    message in context:
http://geomoose-users.964460.n3.nabble.com/Identify-Feture-not-working-on-la
yers-tp3243706p3243706.html
>>>Sent
    from the Geomoose-users mailing list archive at
    Nabble.com.
>>>uberSVN's
    rich system and user administration capabilities and model
>>>configuration
    take the hassle out of deploying and managing Subversion and
>>>the tools
    developers use with it. Learn more about uberSVN and get a free
>>>download
    at:? http://p.sf.net/sfu/wandisco-dev2dev
>>>_______________________________________________
>>>Geomoose-users
>>>Geomoose-users at lists.sourceforge.net
Message: 2
Date: Thu, 11 Aug 2011 08:58:22 -0600
To: "'Dan Little'" <danlittle at yahoo.com>,    "'Brian Fischer'"
Message-ID: <A9F4EB55F8104D1783C7F34255ED1B6B at emery9e1eeaf61>
Content-Type: text/plain; charset="us-ascii"
Dan Little,
Here are the contents of the identify tool using firebug and firefox.  I
hope this is what you wanted to look at.
Detailed information for the area you clicked on the map...
<table border="0">
<tr>
<br>
<b>X: </b>1751465
<br>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
<tr>
<td colspan="2">Disclaimer: This information is being distributed as
demonstation data only.  You should not use the data for any other
purposes.</td>
</tr>
</table>
Brian Fischer,
I'd like to see the actual contents being sent back.  I'm not 100% sure
  _____
I am doing an upgrade from a 1.x geomoose install.  I have my esri layers
showing up in geomoose, but when I try to do an identify on the layers I
only return the default X and Y coordinate template.  I have looked through
the wiki, the online forum, and online searches and tried to make my data
fit with what is presented but I still can't get identify to work.  Also a
wierd thing that happens when I try to do a identify I get 1kb PNG files
that populate the folder that contains the layer mapbook file.  Please point
me in the right direction.  The identify tool is great for what we are
trying to do with Geomoose, but if it is temperamental then maybe I should
stick with the working 1.x install.  Only problem with that is some of the
features don't work in the newer browsers.  Thanks.  Clinton
This is what I have in the mapbook.xml file:
<service name="identify" title="Identify" display="false">
<url>php/identify.php</url> <step type="spatial" name="shape" line="false"
polygon="false" jump-start="true" default="point"> <input
type="visiblelayers" name="layers"/> </step> </service> __________
<tool name="identify" title="Identify" type="service" service="identify"/>
__________
In the layer mapbook I have:
LAYER
NAME            "PRECINCTS"
    STATUS        DEFAULT
    TYPE            POLYGON
    TOLERANCE        3
    CLASSITEM        "NAME"
    LABELITEM        "NAME"
    CLASS
            STYLE
                COLOR 255 102 0
                SIZE 2
            END
          LABEL
                    TYPE TRUETYPE
                    FONT vera_sans-bold
                    SIZE 8
                    ANTIALIAS true
                    COLOR 153 0 153
                    BUFFER 3
                    MINFEATURESIZE auto
                    PARTIALS FALSE
                    POSITION ul
            END
    END
METADATA
END
END
View this message in context:
Sent from the Geomoose-users mailing list archive at Nabble.com.
uberSVN's rich system and user administration capabilities and model
configuration take the hassle out of deploying and managing Subversion and
the tools developers use with it. Learn more about uberSVN and get a free
download at:  http://p.sf.net/sfu/wandisco-dev2dev
Geomoose-users mailing list Geomoose-users at lists.sourceforge.net
Get a FREE DOWNLOAD! and learn more about uberSVN rich system,
user administration capabilities and model configuration. Take
the hassle out of deploying and managing Subversion and the
End of Geomoose-users Digest, Vol 47, Issue 13
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110811/91a47295/attachment.html
More information about the Geomoose-users mailing list
