[Geomoose-users] Feature Editor: Polygon_update and Polygon_delete Errors
Brent Fraser bfraser at geoanalytic.com
Wed Dec 7 10:20:47 EST 2011
Well the PHP is pretty simple for the delete:
     } else if($operation == 'delete') {
             if($feature_info[$primaryKeyColumn] < 1) {
                     print 'No Feature ID specified to delete.<br/>';
                     die;
So what that tells me is that the value passed from the browser is <1.
Possibly your identity.html has a syntax problem?  And what is the
content of the "Delete" link when you do an identify on the polygon?
Best Regards,
Brent Fraser
On 12/6/2011 11:03 PM, Atif Butt wrote:
> Yes
> this is my test_polygon.ini file settings
> ; Basic Connection Information
>        host=localhost
>        dbname=postgis
>        username=postgres
>        password=xxxxxxx
> ; Table Information
>        tablename=test_polygons
>        geometry_column=wkb_geometry
>        primary_key_column=polygon_id
>        primary_key_sequence=test_polygons_seq
>        srid=26915
> ; Required Columns
> ; This is a comma separated list of columns required
> ; for creating or updating features in this layer
>       required_for_create=wkb_geometry,title
>       required_for_update=title
> ; GeoMOOSE Information
>        layerpath=poly_editor/polygons
> Regards
> Atif
> On Tue, Dec 6, 2011 at 11:24 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Do you have the primary_key_column defined in the ini file?
>     Best Regards,
>     Brent Fraser
>     On 12/6/2011 7:24 PM, Atif Butt wrote:
>>     Hi
>>     Is there any other steps needs to do (except written inside the
>>     feature editor document) for "polygon_update and ploygon_delete".
>>     Because after doing these steps, when I use update polygon
>>     feature I am getting this message (1No Feature ID available for
>>     update.) and when I use delete_polygon tool, it says "No Feature
>>     ID specified to delete."
>>     I think something is missing.
>>     kindly check (http://99.243.192.221/geomoose2/geomoose.html) and
>>     give me your suggestions.
>>     Best Regards
>>     Atif
>>     _______________________________________________
>>     Geomoose-users mailing list
>>     Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111207/fb58865c/attachment.html
More information about the Geomoose-users mailing list
