[Geomoose-users] Feature Editor: Polygon_update and Polygon_delete Errors
Atif Butt matifbutt at gmail.com
Sun Dec 11 14:54:39 EST 2011
Hi Brent
I used the following code, for the identify.html file.
Kindly have a look. http://141.117.248.26/geomoose2/geomoose.html
<!-- MapServer Template -->
<tr bgcolor="#AA55AA">
<td colspan="2"><b>[title] ([polygon_id])</b></td>
</tr>
<tr>
<td>Owner:</td><td>[owner]</td>
</tr>
<tr>
<td>
<a href="javascript:GeoMOOSE.startService('modify_polygon',
{'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' :
'[wkt_geometry]', 'feature:title' : '[title]', 'feature:owner' :
'[owner]'})">Edit</a>
</td>
<td>
<a href="javascript:if(confirm('Are you sure you want to delete this?')) {
GeoMOOSE.startService('delete_polygon', {'feature:polygon_id' :
'[polygon_id]'}); }">Delete</a>
</td>
</tr>
Secondly, why the above geomoose link can only be working inside firefox,
why not IE, and chrome, etc. Do you have any idea ?
Best regards
Atif
On Wed, Dec 7, 2011 at 10:20 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Well the PHP is pretty simple for the delete:
>     } else if($operation == 'delete') {
>             if($feature_info[$primaryKeyColumn] < 1) {
>                     print 'No Feature ID specified to delete.<br/>';
>                     die;
> So what that tells me is that the value passed from the browser is <1.
> Possibly your identity.html has a syntax problem?  And what is the content
> of the "Delete" link when you do an identify on the polygon?
> Best Regards,
> Brent Fraser
> On 12/6/2011 11:03 PM, Atif Butt wrote:
> Yes
> this is my test_polygon.ini file settings
> ; Basic Connection Information
>        host=localhost
>        dbname=postgis
>        username=postgres
>        password=xxxxxxx
> ; Table Information
>        tablename=test_polygons
>        geometry_column=wkb_geometry
>        primary_key_column=polygon_id
>        primary_key_sequence=test_polygons_seq
>        srid=26915
> ; Required Columns
> ; This is a comma separated list of columns required
> ; for creating or updating features in this layer
>       required_for_create=wkb_geometry,title
>       required_for_update=title
> ; GeoMOOSE Information
>        layerpath=poly_editor/polygons
> Regards
> Atif
> On Tue, Dec 6, 2011 at 11:24 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>  Do you have the primary_key_column defined in the ini file?
>> Best Regards,
>> Brent Fraser
>> On 12/6/2011 7:24 PM, Atif Butt wrote:
>>  Hi
>> Is there any other steps needs to do (except written inside the feature
>> editor document) for "polygon_update and ploygon_delete". Because after
>> doing these steps, when I use update polygon feature I am getting this
>> message (1No Feature ID available for update.) and when I use
>> delete_polygon tool, it says "No Feature ID specified to delete."
>> I think something is missing.
>> kindly check (http://99.243.192.221/geomoose2/geomoose.html) and give me
>> your suggestions.
>> Best Regards
>> Atif
>>  _______________________________________________
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111211/11995032/attachment.html
More information about the Geomoose-users mailing list
