[Geomoose-users] Feature Editor: Polygon_update and Polygon_delete Errors
Brent Fraser bfraser at geoanalytic.com
Sun Dec 11 15:37:09 EST 2011
Have a look at
http://www.geomoose.org/docs/feature_editor.html
Best Regards,
Brent Fraser
On 12/11/2011 1:24 PM, Atif Butt wrote:
> I got your point now, I was thinking it may be setup already.
> Any how from where you want me to start (any document reference or URL
> talking about delete and modify service  ), Or you suggest me to see
> the builtin service of geomoose (in relation to modify /delete polygon).
> Give me your suggestions
> Thanks and regards
> Atif
> On Sun, Dec 11, 2011 at 3:18 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
>     Atif,
>       The Feature Editor doc on the Geomoose site uses the results of
>     the Identify operation to render a link to delete the selected
>     feature.  Your mapbook creates a "delete_polygon" button on the
>     tool bar referencing the a delete_polygon service:
>     <service name="delete_polygon">
>     <url>php/editor.php</url>
>     <step type="input">
>     <input type="hidden" name="op" value="delete"/>
>     <input type="hidden" name="table" value="test_polygons"/>
>     <input type="hidden" name="feature:polygon_id"/>
>     </step>
>     </service>
>     Since your service has no spatial step (only a form input step),
>     there is no way for the user to select the polygon to delete.
>       You need to look at the Feature Editor doc and get your editing
>     functions working as documented first, then you would be in a
>     better position to expand it by adding tool bar buttons to do
>     delete and modify.
>     Best Regards,
>     Brent Fraser
>     On 12/11/2011 12:54 PM, Atif Butt wrote:
>>     Hi Brent
>>     I used the following code, for the identify.html file.
>>     Kindly have a look. http://141.117.248.26/geomoose2/geomoose.html
>>     <!-- MapServer Template -->
>>     <tr bgcolor="#AA55AA">
>>     <td colspan="2"><b>[title] ([polygon_id])</b></td>
>>     </tr>
>>     <tr>
>>     <td>Owner:</td><td>[owner]</td>
>>     </tr>
>>     <tr>
>>     <td>
>>     <a href="javascript:GeoMOOSE.startService('modify_polygon',
>>     {'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' :
>>     '[wkt_geometry]', 'feature:title' : '[title]', 'feature:owner' :
>>     '[owner]'})">Edit</a>
>>     </td>
>>     <td>
>>     <a href="javascript:if(confirm('Are you sure you want to delete
>>     this?')) { GeoMOOSE.startService('delete_polygon',
>>     {'feature:polygon_id' : '[polygon_id]'}); }">Delete</a>
>>     </td>
>>     </tr>
>>     Secondly, why the above geomoose link can only be working inside
>>     firefox, why not IE, and chrome, etc. Do you have any idea ?
>>     Best regards
>>     Atif
>>     On Wed, Dec 7, 2011 at 10:20 AM, Brent Fraser
>>     <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>>         Well the PHP is pretty simple for the delete:
>>             } else if($operation == 'delete') {
>>                     if($feature_info[$primaryKeyColumn] < 1) {
>>                             print 'No Feature ID specified to
>>         delete.<br/>';
>>                             die;
>>         So what that tells me is that the value passed from the
>>         browser is <1.  Possibly your identity.html has a syntax
>>         problem?  And what is the content of the "Delete" link when
>>         you do an identify on the polygon?
>>         Best Regards,
>>         Brent Fraser
>>         On 12/6/2011 11:03 PM, Atif Butt wrote:
>>>         Yes
>>>         this is my test_polygon.ini file settings
>>>         ; Basic Connection Information
>>>                host=localhost
>>>                dbname=postgis
>>>                username=postgres
>>>                password=xxxxxxx
>>>         ; Table Information
>>>                tablename=test_polygons
>>>                geometry_column=wkb_geometry
>>>                primary_key_column=polygon_id
>>>                primary_key_sequence=test_polygons_seq
>>>                srid=26915
>>>         ; Required Columns
>>>         ; This is a comma separated list of columns required
>>>         ; for creating or updating features in this layer
>>>               required_for_create=wkb_geometry,title
>>>               required_for_update=title
>>>         ; GeoMOOSE Information
>>>                layerpath=poly_editor/polygons
>>>         Regards
>>>         Atif
>>>         On Tue, Dec 6, 2011 at 11:24 PM, Brent Fraser
>>>         wrote:
>>>             Do you have the primary_key_column defined in the ini file?
>>>             Best Regards,
>>>             Brent Fraser
>>>             On 12/6/2011 7:24 PM, Atif Butt wrote:
>>>>             Hi
>>>>             Is there any other steps needs to do (except written
>>>>             inside the feature editor document) for "polygon_update
>>>>             and ploygon_delete". Because after doing these steps,
>>>>             when I use update polygon feature I am getting this
>>>>             message (1No Feature ID available for update.) and when
>>>>             I use delete_polygon tool, it says "No Feature ID
>>>>             specified to delete."
>>>>             I think something is missing.
>>>>             kindly check
>>>>             (http://99.243.192.221/geomoose2/geomoose.html) and
>>>>             give me your suggestions.
>>>>             Best Regards
>>>>             Atif
>>>>             _______________________________________________
>>>>             Geomoose-users mailing list
>>>>             Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>>>>             http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111211/8fd9d8ec/attachment-0001.html
More information about the Geomoose-users mailing list
