[Geomoose-users] Feature Editor: Polygon_update and Polygon_delete Errors
Atif Butt matifbutt at gmail.com
Mon Dec 12 00:31:53 EST 2011
Hi Brent
This docs has only explained the delete  and modify polygon servies as
follow:
<service name="delete_polygon">
        <url>php/editor.php</url>
        <step type='input'>
                <input type="hidden" name="op" value="delete"/>
                <input type="hidden" name="table" value="test_polygons"/>
                <input type="hidden" name="feature:polygon_id"/>
        </step>
</service>
similarly, modify_polygon service as
<service name="modify_polygon">
        <step type='spatial' name='feature:wkb_geometry' line='false'
polygon='true' point='false' default='point' edit-polygon='true'> <!-- It's
necessary to specify that the polygon editor be turned on, the rest of the
options are CREATION functions -->
                <input type="hidden" name="op" value="update"/>
                <!-- This just changes the option to 'update' instead of
'create' -->
                <input type="user" name="feature:title" title="Title:"/>
                <input type="user" name="feature:owner" title="Owner:"/>
        </step>
</service>
If you talking about these steps, then I have already done with them. I
dont know, maybe something else conflicting or left to be perfromed.
The URL for checking the results so far (use firefox to open):
http://141.117.248.26/geomoose2/geomoose.html
You can check my mapbook.xml or anyother documents related to the
feature_editor_configuration from this URL, I put all configuration
files together in one folder; acessable at:
http://141.117.248.26/geomoose2/Development_Docs/
 e.g., mapbook.xml can be accessed at URL=
http://141.117.248.26/geomoose2/Development_Docs/conf/mapbook.xml
Best Regards and Thanks for quick response
Atif
On Sun, Dec 11, 2011 at 3:37 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  Have a look at
> http://www.geomoose.org/docs/feature_editor.html
> Best Regards,
> Brent Fraser
> On 12/11/2011 1:24 PM, Atif Butt wrote:
> I got your point now, I was thinking it may be setup already.
> Any how from where you want me to start (any document reference or URL
> talking about delete and modify service  ), Or you suggest me to see the
> builtin service of geomoose (in relation to modify /delete polygon).
> Give me your suggestions
> Thanks and regards
> Atif
>  On Sun, Dec 11, 2011 at 3:18 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>  Atif,
>>   The Feature Editor doc on the Geomoose site uses the results of the
>> Identify operation to render a link to delete the selected feature.  Your
>> mapbook creates a "delete_polygon" button on the tool bar referencing the a
>> delete_polygon service:
>>   <step type="input">
>>   </step>
>> </service>
>> Since your service has no spatial step (only a form input step), there is
>> no way for the user to select the polygon to delete.
>>   You need to look at the Feature Editor doc and get your editing
>> functions working as documented first, then you would be in a better
>> position to expand it by adding tool bar buttons to do delete and modify.
>> Best Regards,
>> Brent Fraser
>> On 12/11/2011 12:54 PM, Atif Butt wrote:
>> Hi Brent
>> I used the following code, for the identify.html file.
>> Kindly have a look. http://141.117.248.26/geomoose2/geomoose.html
>> <!-- MapServer Template -->
>> <tr bgcolor="#AA55AA">
>> <td colspan="2"><b>[title] ([polygon_id])</b></td>
>> </tr>
>> <tr>
>> <td>Owner:</td><td>[owner]</td>
>> </tr>
>> <tr>
>> <td>
>> <a href="javascript:GeoMOOSE.startService('modify_polygon',
>> {'feature:polygon_id' : '[polygon_id]','feature:wkb_geometry' :
>> '[wkt_geometry]', 'feature:title' : '[title]', 'feature:owner' :
>> '[owner]'})">Edit</a>
>> </td>
>> <td>
>> <a href="javascript:if(confirm('Are you sure you want to delete this?'))
>> { GeoMOOSE.startService('delete_polygon', {'feature:polygon_id' :
>> '[polygon_id]'}); }">Delete</a>
>> </td>
>> </tr>
>> Secondly, why the above geomoose link can only be working inside firefox,
>> why not IE, and chrome, etc. Do you have any idea ?
>> Best regards
>> Atif
>> On Wed, Dec 7, 2011 at 10:20 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>>  Well the PHP is pretty simple for the delete:
>>>     } else if($operation == 'delete') {
>>>             if($feature_info[$primaryKeyColumn] < 1) {
>>>                     print 'No Feature ID specified to delete.<br/>';
>>>                     die;
>>> So what that tells me is that the value passed from the browser is <1.
>>> Possibly your identity.html has a syntax problem?  And what is the content
>>> of the "Delete" link when you do an identify on the polygon?
>>> Best Regards,
>>> Brent Fraser
>>> On 12/6/2011 11:03 PM, Atif Butt wrote:
>>> Yes
>>> this is my test_polygon.ini file settings
>>> ; Basic Connection Information
>>>        host=localhost
>>>        dbname=postgis
>>>        username=postgres
>>>        password=xxxxxxx
>>> ; Table Information
>>>        tablename=test_polygons
>>>        geometry_column=wkb_geometry
>>>        primary_key_column=polygon_id
>>>        primary_key_sequence=test_polygons_seq
>>>        srid=26915
>>> ; Required Columns
>>> ; This is a comma separated list of columns required
>>> ; for creating or updating features in this layer
>>>       required_for_create=wkb_geometry,title
>>>       required_for_update=title
>>> ; GeoMOOSE Information
>>>        layerpath=poly_editor/polygons
>>> Regards
>>> Atif
>>> On Tue, Dec 6, 2011 at 11:24 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>>>  Do you have the primary_key_column defined in the ini file?
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 12/6/2011 7:24 PM, Atif Butt wrote:
>>>>  Hi
>>>> Is there any other steps needs to do (except written inside the feature
>>>> editor document) for "polygon_update and ploygon_delete". Because after
>>>> doing these steps, when I use update polygon feature I am getting this
>>>> message (1No Feature ID available for update.) and when I use
>>>> delete_polygon tool, it says "No Feature ID specified to delete."
>>>> I think something is missing.
>>>> kindly check (http://99.243.192.221/geomoose2/geomoose.html) and give
>>>> me your suggestions.
>>>> Best Regards
>>>> Atif
>>>>  _______________________________________________
>>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111212/00252052/attachment.html
More information about the Geomoose-users mailing list
