[Geomoose-users] URL parameters
Carl Burn burnsy at northcountrywoods.co.uk
Tue Feb 8 11:05:19 EST 2011
Hello again,
I took a look at this and the code I think I need to alter is pretty much
this section of the config.php file:
# Load the configration file
$CONFIGURATION = parse_ini_file('../../conf/settings.ini');
function getMapbook() {
global $CONFIGURATION;
$mapbook = new DOMDocument();
$mapbook->load('../../conf/'.$CONFIGURATION['mapbook']);
return $mapbook;
I am a CF person not a php person (so bear with me) but this looks like it
gets the mapbook from the settings.ini, reads it and then puts the content
into a variable called mapbook. So if I can modify this functionality to
take the details from the url parameter I am passing in then that should be
it, the security I can handle in other ways.
Is this making sense?
Carl
On Tue, Feb 8, 2011 at 3:43 PM, Carl Burn <burnsy at northcountrywoods.co.uk>wrote:
> Hello all,
> one thought occurs, how do I go about changing the name of the index file
> that is called when geomoose starts up, at the moment this is geomoose.html.
> Is this simply a case of changing the file name or is it wired into the
> setup of geomoose, if I can alter the file extension then I can see a way to
> solve this easily.
> Carl
> On Tue, Feb 8, 2011 at 3:39 PM, Carl Burn <burnsy at northcountrywoods.co.uk>wrote:
>> Hi,
>> mid afternoon here, still a while to go before I head off...and I think
>> that may be extended so I can resolve this one.
>> I am passing in the parameter for map book every time a user accesses
>> geomoose as they all have unique files...and just to be really fun they are
>> likely to be unique on every visit, so I am generating a mapbook on the fly
>> as the user attempts to access geomoose.
>> Not to sure I understand what you mean by 1 or 2 but I think I may head
>> over and get a copy of 1.x
>> Cheers
>> Carl
>> On Tue, Feb 8, 2011 at 3:24 PM, Dan Little <danlittle at yahoo.com> wrote:
>>> Good morning (at least for me, you're probably trying to leave the office
>>> about now)!
>>> GM2.2 doesn't directly support passing in a mapbook parameter as did the
>>> 1.X series.  The reason for this is three-fold:
>>> 1) It wasn't a terribly popular functionality.
>>> 2) It was a gaping security hole.
>>> 3) It requires all of the subsequent services to know they need to switch
>>> mapbooks.
>>> There are some options, and they all center around modifying the
>>> getMapbook function of config.php.  Two popular solutions:
>>> 1) Parser the "referrer url" from the HTTP header and get the mapbook
>>> parameter from that.
>>> 2) Read a cookie for a login/authorization schema and select the
>>> appropriate mapbook.
>>> *From:* Carl Burn <burnsy at northcountrywoods.co.uk>
>>> *To:* geomoose-users at lists.sourceforge.net
>>> *Sent:* Tue, February 8, 2011 9:18:01 AM
>>> *Subject:* [Geomoose-users] URL parameters
>>> Hi All,
>>> I am passing across a url parameter of mapbook to geomoose and it looks
>>> like it is simply being ignored, for example:
>>> http://www.aqua3.com:2112/geomoose2/geomoose.html?mapbook=62_1364345175.xml
>>> The system simply uses the default mapbook as defined in the config.ini
>>> file and ignores the url parameter totally, I checked the documentation link
>>> for this and my call looks correct. The mapbook file is valid and works if I
>>> put it into the config.ini. I also tried not setting a mapbook in the
>>> config.ini..this results in no map even when the mapbook is specified on the
>>> url as a  parameter.
>>> I know its going to be an obvious one but can someone point out what I
>>> have missed please.
>>> Best
>>> Carl
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110208/de8c59b4/attachment.html
More information about the Geomoose-users mailing list
