[Geomoose-users] URL parameters
Carl Burn burnsy at northcountrywoods.co.uk
Tue Feb 8 10:43:06 EST 2011
Hello all,
one thought occurs, how do I go about changing the name of the index file
that is called when geomoose starts up, at the moment this is geomoose.html.
Is this simply a case of changing the file name or is it wired into the
setup of geomoose, if I can alter the file extension then I can see a way to
solve this easily.
Carl
On Tue, Feb 8, 2011 at 3:39 PM, Carl Burn <burnsy at northcountrywoods.co.uk>wrote:
> Hi,
> mid afternoon here, still a while to go before I head off...and I think
> that may be extended so I can resolve this one.
> I am passing in the parameter for map book every time a user accesses
> geomoose as they all have unique files...and just to be really fun they are
> likely to be unique on every visit, so I am generating a mapbook on the fly
> as the user attempts to access geomoose.
> Not to sure I understand what you mean by 1 or 2 but I think I may head
> over and get a copy of 1.x
> Cheers
> Carl
> On Tue, Feb 8, 2011 at 3:24 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Good morning (at least for me, you're probably trying to leave the office
>> about now)!
>> GM2.2 doesn't directly support passing in a mapbook parameter as did the
>> 1.X series.  The reason for this is three-fold:
>> 1) It wasn't a terribly popular functionality.
>> 2) It was a gaping security hole.
>> 3) It requires all of the subsequent services to know they need to switch
>> mapbooks.
>> There are some options, and they all center around modifying the
>> getMapbook function of config.php.  Two popular solutions:
>> 1) Parser the "referrer url" from the HTTP header and get the mapbook
>> parameter from that.
>> 2) Read a cookie for a login/authorization schema and select the
>> appropriate mapbook.
>> *From:* Carl Burn <burnsy at northcountrywoods.co.uk>
>> *To:* geomoose-users at lists.sourceforge.net
>> *Sent:* Tue, February 8, 2011 9:18:01 AM
>> *Subject:* [Geomoose-users] URL parameters
>> Hi All,
>> I am passing across a url parameter of mapbook to geomoose and it looks
>> like it is simply being ignored, for example:
>> http://www.aqua3.com:2112/geomoose2/geomoose.html?mapbook=62_1364345175.xml
>> The system simply uses the default mapbook as defined in the config.ini
>> file and ignores the url parameter totally, I checked the documentation link
>> for this and my call looks correct. The mapbook file is valid and works if I
>> put it into the config.ini. I also tried not setting a mapbook in the
>> config.ini..this results in no map even when the mapbook is specified on the
>> url as a  parameter.
>> I know its going to be an obvious one but can someone point out what I
>> have missed please.
>> Best
>> Carl
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110208/e4d12e47/attachment.html
More information about the Geomoose-users mailing list
