[Geomoose-users] URL parameters
Carl Burn burnsy at northcountrywoods.co.uk
Tue Feb 8 10:39:29 EST 2011
mid afternoon here, still a while to go before I head off...and I think that
may be extended so I can resolve this one.
I am passing in the parameter for map book every time a user accesses
geomoose as they all have unique files...and just to be really fun they are
likely to be unique on every visit, so I am generating a mapbook on the fly
as the user attempts to access geomoose.
Not to sure I understand what you mean by 1 or 2 but I think I may head over
and get a copy of 1.x
Cheers
Carl
On Tue, Feb 8, 2011 at 3:24 PM, Dan Little <danlittle at yahoo.com> wrote:
> Good morning (at least for me, you're probably trying to leave the office
> about now)!
> GM2.2 doesn't directly support passing in a mapbook parameter as did the
> 1.X series.  The reason for this is three-fold:
> 1) It wasn't a terribly popular functionality.
> 2) It was a gaping security hole.
> 3) It requires all of the subsequent services to know they need to switch
> mapbooks.
> There are some options, and they all center around modifying the getMapbook
> function of config.php.  Two popular solutions:
> 1) Parser the "referrer url" from the HTTP header and get the mapbook
> parameter from that.
> 2) Read a cookie for a login/authorization schema and select the
> appropriate mapbook.
> *From:* Carl Burn <burnsy at northcountrywoods.co.uk>
> *To:* geomoose-users at lists.sourceforge.net
> *Sent:* Tue, February 8, 2011 9:18:01 AM
> *Subject:* [Geomoose-users] URL parameters
> Hi All,
> I am passing across a url parameter of mapbook to geomoose and it looks
> like it is simply being ignored, for example:
> http://www.aqua3.com:2112/geomoose2/geomoose.html?mapbook=62_1364345175.xml
> The system simply uses the default mapbook as defined in the config.ini
> file and ignores the url parameter totally, I checked the documentation link
> for this and my call looks correct. The mapbook file is valid and works if I
> put it into the config.ini. I also tried not setting a mapbook in the
> config.ini..this results in no map even when the mapbook is specified on the
> url as a  parameter.
> I know its going to be an obvious one but can someone point out what I have
> missed please.
> Best
> Carl
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110208/06d4dca3/attachment.html
More information about the Geomoose-users mailing list
