[Geomoose-users] URL parameters
Dan Little danlittle at yahoo.com
Tue Feb 8 10:24:12 EST 2011
Good morning (at least for me, you're probably trying to leave the office about
now)!
GM2.2 doesn't directly support passing in a mapbook parameter as did the 1.X
series.  The reason for this is three-fold:
1) It wasn't a terribly popular functionality.
2) It was a gaping security hole.
3) It requires all of the subsequent services to know they need to switch
mapbooks.
There are some options, and they all center around modifying the getMapbook
function of config.php.  Two popular solutions:
1) Parser the "referrer url" from the HTTP header and get the mapbook parameter
from that.
2) Read a cookie for a login/authorization schema and select the appropriate
mapbook.
>From: Carl Burn <burnsy at northcountrywoods.co.uk>
>To: geomoose-users at lists.sourceforge.net
>Sent: Tue, February 8, 2011 9:18:01 AM
>Subject: [Geomoose-users] URL parameters
>Hi All,
>I am passing across a url parameter of mapbook to geomoose and it looks like it
>is simply being ignored, for example:
>http://www.aqua3.com:2112/geomoose2/geomoose.html?mapbook=62_1364345175.xml
>The system simply uses the default mapbook as defined in the config.ini file and
>ignores the url parameter totally, I checked the documentation link for this and
>my call looks correct. The mapbook file is valid and works if I put it into the
>config.ini. I also tried not setting a mapbook in the config.ini..this results
>in no map even when the mapbook is specified on the url as a  parameter.
>I know its going to be an obvious one but can someone point out what I have
>missed please.
>Best
>Carl
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110208/8a22c586/attachment.html
More information about the Geomoose-users mailing list
