[Geomoose-users] Printing with sketches
Brent Fraser bfraser at geoanalytic.com
Tue Jan 11 14:05:09 EST 2011
I wonder if
SYMBOLSET 'symbols/symbol.sym'
FONTSET 'fonts/fontset.list'
is causing the problem.  AFAIK they are relative to the map file location,
and the standard geomoose distribution doesn't install them.  You could
try removing the symbolset entry and give a full path to the fontset.
Brent
> Hi everyone,
> I am having issues with printing while having shapes (polygons, lines or
> points) drawn on the map. I have narrowed the issue down to a line in
> print_util.php but I can't see what the issue is. In the section: "# now
> add
> the sketches on top of the map..." around line 214 it enters a for loop
> where a new Map Object is created using the following line:
> $sketch_map =
> ms_newMapObj('print/print_shape.map',$CONFIGURATION['root']);
> This seems to not be creating a valid map object because any attempt to
> call
> one of the map object methods on $sketch_map fails. The line it fails on
> in
> print_util is:
> $sketch_map->setExtent($extent[0], $extent[1], $extent[2], $extent[3]);
> but I also tried echo $sketch_map->getNumSymbols(); which fails.
> I have checked to be sure that print_shape.map is in the correct location,
> and even changed the constructor's input to use and explicit full path to
> the file:
> $sketch_map =
> ms_newMapObj("C:\ms4w\apps\maps.development\htdocs\php\print\print_shape.map");
> which has also not worked. Does anyone have any expierience with this
> issue,
> or know why creating the Map Object with ms_newMapObj would be failing?
> Any
> help to debug this would be greatly appreciated!
> Thanks,
> Jeff
> Gaining the trust of online customers is vital for the success of any
> company
> that requires sensitive data to be transmitted over the Web.   Learn how
> to
> best implement a security strategy that keeps consumers' information
> secure
> and instills the confidence they need to proceed with transactions.
> http://p.sf.net/sfu/oracle-sfdevnl
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Best Regards
Brent Fraser
More information about the Geomoose-users mailing list
