[Geomoose-users] identify from wms source
DEAN ANDERSON ANDERSON.DEAN at co.polk.or.us
Thu Jan 13 15:25:05 EST 2011
There is an example of this on the site Houston worked on for us for doing a basic identify (does not do the popup as we did not ask for that).
To see it...
1. go to. http://polkcounty.houstoneng.net/
2. turn on lincoln county taxlots
3. pan to edge of Polk County and lincoln taxlots in gray
4. Identify the  taxlot in Lincoln County - the attributes will display
wms reference in mapbook is...
 <map-source name="test" type="wms" queryable="true">
                <url>http://maps.co.lincoln.or.us/fcgi-bin/mapserv.exe?</url>
  <param name="map" value="/ms4w/apps/lincoln/04/queryLincoln2.map"/>
  <layer name="taxlots" queryable="true" />
  <param name="TRANSPARENT" value="TRUE"/>
  <param name="FORMAT" value="image/gif"/>
       </map-source>
Hope that helps.
Dean Anderson
IT Director
Polk County, OR
>>> "Mark Volz" <MarkVolz at co.lyon.mn.us> 1/13/2011 11:39 AM >>>
Hello,
Is it possible to identify, orproducea popup from a WMS source that supports identify?  And if so the so, canGeomoosedisplaya popup if the WMS returns the identify results in an html page as opposed to text?
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110113/02f44cb9/attachment.html
More information about the Geomoose-users mailing list
