[Geomoose-users] identify from wms source
Len Kne lkne at houstoneng.com
Thu Jan 13 18:34:27 EST 2011
There was a thread on this a while back on the mailing list http://sourceforge.net/mailarchive/message.php?msg_id=25577496.
BTW, the search function is working again on the mailing lists!
Len
From: DEAN ANDERSON [mailto:ANDERSON.DEAN at co.polk.or.us]
Sent: Thursday, January 13, 2011 2:25 PM
To: Mark Volz; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] identify from wms source
There is an example of this on the site Houston worked on for us for doing a basic identify (does not do the popup as we did not ask for that).
To see it...
1. go to. http://polkcounty.houstoneng.net/
2. turn on lincoln county taxlots
3. pan to edge of Polk County and lincoln taxlots in gray
4. Identify the  taxlot in Lincoln County - the attributes will display
wms reference in mapbook is...
 <map-source name="test" type="wms" queryable="true">
                <url>http://maps.co.lincoln.or.us/fcgi-bin/mapserv.exe?</url<http://maps.co.lincoln.or.us/fcgi-bin/mapserv.exe?%3c/url>>
  <param name="map" value="/ms4w/apps/lincoln/04/queryLincoln2.map"/>
  <layer name="taxlots" queryable="true" />
  <param name="TRANSPARENT" value="TRUE"/>
  <param name="FORMAT" value="image/gif"/>
       </map-source>
Hope that helps.
Dean Anderson
IT Director
Polk County, OR
>>> "Mark Volz" <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> 1/13/2011 11:39 AM >>>
Hello,
Is it possible to identify, or produce a popup from a WMS source that supports identify?  And if so the so, can Geomoose display a popup if the WMS returns the identify results in an html page as opposed to text?
Thanks
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110113/33fcc9fe/attachment.html
More information about the Geomoose-users mailing list
