[Geomoose-users] Setting up first geomoose app
Carl Burn burnsy at northcountrywoods.co.uk
Fri Jan 14 09:51:38 EST 2011
yep sorry my error, I have altered the units to DD but am not really any
further forward, I took a look at the data for the layers I need to add and
I think I may need to either alter the projections section in the map file
or reproject the data.
When I check the properties of the file in qgis I get the following:
+proj=tmerc +lat_0=49 +lon_0=-2 +k=0.9996012717 +x_0=400000 +y_0=-100000
+ellps=airy +datum=OSGB36 +units=m +no_defs
Luckily I only need to worry about three data files and they are all
identical in terms of the projection information I can see from the
properties dialogue boxes in qgis.
Does this sound reasonable?
Cheers
Carl
On Fri, Jan 14, 2011 at 1:36 PM, Johan Forsman <Johan.Forsman at la.gov> wrote:
> The extent sections in both of your attached files are still in units
> incompatible with your chosen projection. Did you perhaps attach uncorrected
> versions?
> You indicate units of INCHES in the MAP file but WGS84 is defined by
> decimal degrees (DD). If you are in the UK you ought to be inside a box
> described by (-11 49 2 61), or something similar to that provided I have the
> bottom-left top-right sequence correct.
> /Johan.
> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
> *Sent:* Friday, January 14, 2011 5:35 AM
> *To:* geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] Setting up first geomoose app
> Hi, still banging up against a brick wall with this one. I have taken some
> advice and resolved the extent issues in my map file and xml file. I have
> also modified the map and xml files so that they are considerably simpler,
> figuring that if its simpler it will be easier to spot my mistakes. I have
> attached the two files to this mail, not sure if this is allowed on the
> listserver.
> Here is what else I have tried:
> 1. Ran the mapfile through shp2img and it is not generating any error
> messages at all, though the time to draw the layer comes in at 0.000s which
> seems odd to me.
> 2. Ran a get capabilities request on the map file and got the xml back,
> this is not reporting any errors.
> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:\ms4w\apps\geomoose2\maps\arcview\testshp.map<http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png>
> &SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
> 3. Ran a get map request to generate a map image, again I can see this
> without any errors.
> http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:\ms4w\apps\geomoose2\maps\arcview\testshp.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=testlayer&STYLES=&SRS=EPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png<http://www.aqua3.com:2112/cgi-bin/mapserv.exe?map=d:%5Cms4w%5Capps%5Cgeomoose2%5Cmaps%5Carcview%5Ctestshp.map%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetMap%26LAYERS%3Dtestlayer%26STYLES%3D%26SRS%3DEPSG:4326&BBOX=-990487.465830,-31957.211592,1696934.624449,1261986.757801&WIDTH=400&HEIGHT=600&FORMAT=image/png>
> 4. Connected to the wms layer with QGIS as my client, the map image appears
> with no errors.
> I am totally lost at this point and have no idea why the map image is not
> appearing, any clues would be most welcome.
> Carl
> On Thu, Jan 13, 2011 at 9:32 PM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
> And while you've got a <map-source> defined, I don't think there's a
> <Layer> set up to reference it.
> Brent
> > Carl,
> > One problem is that the coordinate system is defined as longlat, but the
> > extent is given is something other than decimal degrees:
> >   EXTENT -990487.465830 -31957.211592 1696934.624449 1261986.757801
> >   PROJECTION
> >      'init=epsg:4326'
> >     'proj=longlat'
> >     'ellps=WGS84'
> >     'datum=WGS84'
> >     'no_defs'
> >   END
> > And in the mapbook as well.
> > Brent
> >> Hi,
> >> trying to get a basic app working in geomoose using our own data and I
> >> am
> >> getting a blank map area. I have set up a simple map file in the
> >> standard
> >> ms4w maps folder in a folder called ArcView, I have put my map file in
> >> to
> >> that folder and have tested it using a browser and can see a map and am
> >> able
> >> to download an xml document when I do a get capabilities request.
> >> The map file is as follows:
> >> ============== MAP FILE =======================
> >> MAP
> >>   NAME "TESTMAP"
> >>   # Map image size
> >>   SIZE 800 800
> >>   UNITS INCHES
> >>   FONTSET     "../fonts/fontset.list"
> >>     SYMBOLSET    "../symbols/symbol.sym"
> >>   PROJECTION
> >>      'init=epsg:4326'
> >>     'proj=longlat'
> >>     'ellps=WGS84'
> >>     'datum=WGS84'
> >>     'no_defs'
> >>   END
> >>   IMAGECOLOR 255 255 255
> >>   IMAGEQUALITY 95
> >>   IMAGETYPE jpeg
> >>   OUTPUTFORMAT
> >>     NAME jpeg
> >>     DRIVER 'GD/JPEG'
> >>     MIMETYPE 'image/jpeg'
> >>     IMAGEMODE RGBA
> >>     EXTENSION 'jpeg'
> >>   END
> >>   LEGEND
> >>     STATUS ON
> >>     KEYSIZE 18 12
> >>     LABEL
> >>       TYPE BITMAP
> >>       SIZE MEDIUM
> >>       COLOR 0 0 89
> >>     END
> >>   END
> >>   WEB
> >>     IMAGEPATH '/tmp/'
> >>     IMAGEURL '/tmp/'
> >>     METADATA
> >>       'ows_title'           'TESTMAP'
> >>       'ows_onlineresource'  'http://www.*ourserver*
> >> .com:2112/cgi-bin/mapserv.exe?map=testshp.map'
> >>       'ows_srs'             'EPSG:4326'
> >>     END
> >>     TEMPLATE 'foo'
> >>   END
> >>   LAYER
> >>     NAME 'RECTANGLES'
> >>     TYPE POLYGON
> >>     DUMP true
> >>     TEMPLATE fooOnlyForWMSGetFeatureInfo
> >>     DATA 'D:/ms4w/apps/geomoose2/maps/ArcView/seamless_rectangle.shp'
> >>     METADATA
> >>       'ows_title' 'rectangles'
> >>     END
> >>     STATUS OFF
> >>     TRANSPARENCY 100
> >>     PROJECTION
> >>     'init=epsg:4326'
> >>     'proj=longlat'
> >>     'ellps=WGS84'
> >>     'datum=WGS84'
> >>     'no_defs'
> >>     END
> >>     CLASS
> >>        NAME 'seamless_rectangle'
> >>        STYLE
> >>          WIDTH 1
> >>          OUTLINECOLOR 0 0 0
> >>          COLOR 149 170 154
> >>        END
> >>     END
> >>   END
> >> END
> >> =============== END OF MAP FILE=================
> >> The map book .xml is as follows, just a commented out version of the
> >> original one:
> >> ============== MAPBOOK.XML ===================
> >> <?xml version="1.0"?>
> >> <mapbook version="2.0">
> >>     <configuration>
> >>             <param name="links_bar_html"><![CDATA[Perfect timing for
> >> some
> >> damn CDATA "all" of 'its' here <&>]]></param>
> >>             <param name="layer_controls.unfade.on">false</param>
> >>         <!--    <param name="zoomto['Jump To:']"><![CDATA[
> >>             'Dakota County' :
> >> [521238.614537864,4924218.86673578,473921.947801381,4974430.36885032],
> >>             'Parcel Data' :
> >> [497205.409367,4923984.423582,477595.805945,4941970.52988],
> >>             'Full State of MN' :
> >> [189783.560000,4816309.330000,761653.524114,5472346.500000]
> >>         ]]></param> -->
> >>         <param
> name="max_extent">-1053325.991731,-63036.027500,1763261.991731,1293098.927500</param>
> >>         <param
> name="initial_extent">-990487.465830,-31957.211592,1696934.624449,1261986.757801</param>
> >>         <param name="layer_controls.legend.on">false</param>
> >>         <param name="mapserver_url">/cgi-bin/mapserv.exe</param>
> >>         <param name="mapfile_root">/ms4w/apps/geomoose2/maps/</param>
> >>         <param name="projection">EPSG:4326</param>
> >>         <param name="layer_controls.up.on">false</param>
> >>         <param name="layer_controls.down.on">false</param>
> >>         <param name="layer_controls.legend.on">true</param>
> >>         <param name="drawing_tools.default_fill">red</param>
> >>         <param name="drawing_tools.default_stroke">yellow</param>
> >>         <param name="drawing_tools.default_opacity">1</param>
> >>         <param name="group_checkboxes">false</param>
> >>         <param name="default_tab">Catalog</param>
> >>         <param name="catalog_name">Catalog</param>
> >>         <param name="show_service_settings_in">Information</param>
> >>         <param name="show_results_in">Information</param>
> >>         <param name="tabs"><![CDATA[
> >>              'Catalog' : 'catalog-tab',
> >>              'Information' : 'information-tab',
> >>              'Custom' : 'custom-tab'
> >>          ]]></param>
> >>         <param name="ground_units">km</param>
> >>         <param
> >> name="scales">.5,1,4,8,16,24,32,64,128,270,550,1000</param>
> >>         <param name="reference_map.enabled">false</param>
> >>         <param name="coordinate_display.usng">false</param>
> >>         <param name="jumpto_scales"><![CDATA[
> >>             '1:50000' : 50000,
> >>             '1:24000' : 24000,
> >>             '1:10000' : 10000,
> >>             '1:5000' : 5000
> >>     ]]></param>
> >>     </configuration>
> >>         The mapping services define the source of the mapping data.
> >>     <map-source name="highlight" type="mapserver">
> >>         <file/>
> >>         <layer name="all"/>
> >>     </map-source>
> >>     <map-source name="TESTMAP" type="mapserver">
> >>         <file>./ArcView/testshp.map</file>
> >>         <layer name="rectangles"/>
> >>     </map-source>
> >>     <!--    <map-source name="borders" type="mapserver"
> >> reference="true">
> >>         <file>./demo/statedata/basemap.map</file>
> >>         <layer name="all"/>
> >>     </map-source>
> >>     <map-source name="iastate" type="wms" tiled="false"
> >> projection="EPSG:900913" width="512" height="512">
> >>         <url>
> http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi
> >> </url>
> >>         <layer name="nexrad-n0r"/>
> >>         <param name="format" value="image/jpeg"/>
> >>         <param name="TRANSPARENT" value="TRUE"/>
> >>     </map-source>
> >>     <map-source name="metbase" type="ags" >
> >>         <url>
> http://gis.metc.state.mn.us/ArcGIS/rest/services/BaseLayer/UTMBaseMap/MapServer/export
> >> </url>
> >>         <layer name="Met Council Base Map Layers" />
> >>         <param name="FORMAT" value="JPG"/>
> >>     </map-source>
> >>     <map-source name="lmic" type="wms" tiled="false">
> >>         <url>http://geoint.lmic.state.mn.us/cgi-bin/wms</url>
> >>         <layer name="fsa2008"/>
> >>         <layer name="bw1997"/>
> >>     </map-source>
> >>     <map-source name="usgs_doq" type="wms" tiled="false"
> >> projection='EPSG:26915'>
> >>         <url>http://terraservice.net/ogcmap.ashx?</url>
> >>         <layer name="DOQ"/>
> >>     </map-source>
> >>     <map-source name="usgs_drg" type="wms" tiled="false"
> >>         <layer name="DRG"/>
> >>     </map-source>
> >>     <map-source name="reference" type="wms" tiled="false"
> >> reference="true">
> >>         <layer name="fsa2008" reference="true" />
> >>     </map-source> -->
> >>     <service name="print" title="Print Map">
> >>         <step type="input">
> >>             <url>php/print.php</url>
> >>             <input type="print_info" name="layers"/>
> >>             <input type="extent" name="extent"/>
> >>             <input type="sketches" name="sketches"/>
> >>             <input type="user" name="title" title="Map
> >> Title">Map</input>
> >>             <input type="hidden" name="date" title="Map
> >> Date">true</input>
> >>             <input type="select" name="template" title="Output Template:
> >>                 <option value="letter_landscape">Letter -
> >> Landscape</option>
> >>                 <option value="letter_portrait">Letter -
> >> Portrait</option>
> >>                 <option value="poster_landscape">11" x 17" -
> >> Landscape</option>
> >>                 <option value="poster_portrait">11" x 17" -
> >> Portrait</option>
> >>             </input>
> >>             <input type="select" name="quality" title="Image Quality: ">
> >>                 <option value="2">Higher</option>
> >>                 <option value="3">Highest</option>
> >>                 <option value="1">Standard</option>
> >>             </input>
> >>             <input type="select" name="scale" title="Preserve Scale: ">
> >>                 <option value="preserve">Yes</option>
> >>                 <option value="no">No</option>
> >>             </input>
> >>         </step>
> >>     </service>
> >>     <service name="identify" title="Identify" display="false">
> >>         <url>php/identify.php</url>
> >>         <step type="spatial" name="shape" line="false" polygon="false"
> >> jump-start="true" default="point">
> >>             <input type="visiblelayers" name="layers"/>
> >>         </step>
> >>     </service>
> >>     <service name="birdseye" display="false" target="_blank">
> >>         <url>php/birdseye.php</url>
> >>         <step type="spatial" name="xy" line="false" polygon="false"
> >> jump-start="true" default="point" format="delim" reproject="EPSG:4326">
> >>         </step>
> >>     </service>
> >>     <service name="streetview" display="false" target="_blank">
> >>         <url>php/streetview.php</url>
> >>         </step>
> >>     </service>
> >>     <service name="feature_report" display="false">
> >>         <url>php/feature_report.php</url>
> >>         <input type="hidden" name="layers" value="lmic/fsa"/>
> >>         <input type="hidden" name="src"/>
> >>         <input type="hidden" name="PIN"/>
> >>     </service>
> >>     <service name="select" title="Select">
> >>         <url>php/select.php</url>
> >>         <!-- Send a selection shape + the visible layers list to the
> >> service
> >>         <step type="spatial" showTools="true" name="shape" line="true"
> >> polygon="true" point="true" default="polygon" edit-polygon="false"
> >> pan="false" jump-start="true">
> >>             <header><![CDATA[Create a selection area by clicking on the
> >> map.]]></header>
> >>                 Option values should be the mapbook path to the layer.
> >>                 This only supports 'mapserver'-type layers.
> >>             <input type="select" name="select_layer" title="Select:">
> >>                 <option value="parcels/parcels">Parcels</option>
> >>             </input>
> >>             <input type="user" name="shape_buffer" title="Buffer
> >> Selection
> >> Shape (ft)">0</input>
> >>             <input type="select" name="query_layer" title="Using
> >> Features
> >> In">
> >>             </input>
> >> Selection
> >>             <footnote><![CDATA[
> >>             ]]></footnote>
> >>         </step>
> >>     </service>
> >>     <!-- this is called after a standard select in order to buffer the
> >> previous selection -->
> >>     <service name="buffered_select_followup" title="Buffered Select">
> >>         <step type="input">
> >>             <input type="hidden" name="shape"/>
> >>             <input type="hidden" name="select_layer"/>
> >>             <input type="hidden" name="query_layer"/>
> >>             <input type="hidden" name="shape_buffer"/>
> >>             <input type="user" name="selection_buffer" title="Buffer
> >> Features By: "/>
> >>         </step>
> >>     </service>
> >>     <service name="buffered_select" title="Buffered Select">
> >> service
> >> pan="false">
> >> map.]]></header>
> >> features
> >> from:">
> >>             </input>
> >> Selected Features (ft)">0</input>
> >> <!--            <input type="user" name="shape_buffer" title="Buffer
> >> Selection Shape (ft)">0</input>
> >> Features
> >> In">
> >>             </input>
> >>             <footnote><![CDATA[
> >>             ]]></footnote>
> >>         </step>
> >>     </service>
> >>     <service name="popups" display="false">
> >>         <url>php/popups.php</url>
> >>             <header><![CDATA[
> >>             Click on the map to show a popup about the features.
> >>             ]]></header>
> >>             <input type="hidden" name="layer"/>
> >>         </step>
> >>     </service>
> >>     <service name="geocode_address" title="Geocode Address">
> >>         <url>php/geocode.php</url>
> >>         <step type="input">
> >>             <input type="user" name="address" title="Enter Address: "/>
> >>             <input type="hidden" name="googlekey"
> value="ABQIAAAA4Q-VLyIpwp3L8M9DIzKb2BT2yXp_ZAY8_ufC3CFXhHIE1NvwkxRe8Hd6FR51Hvb-Fvd-wGjiDZDC4w"/>
> >>         </step>
> >>     </service>
> >>     <service name="search_parcels">
> >>         <url>php/query.php</url>
> >>         <step type="input">
> >>             <input type="hidden" name="highlight" value="true"/>
> >>             <input type="hidden" name="mode" value="search"/>
> >>             <input type="hidden" name="layer0" value="parcels/parcels"/>
> >>             <input type="hidden" name="template0" value="itemquery"/>
> >>             <input type="select" name="fieldname0" title="Search By:">
> >>                 <option value="OWNER_NAME">Owner</option>
> >>                 <option value="PIN">Parcel ID</option>
> >>             </input>
> >>             <input type="select" name="comparitor0" title="That: ">
> >>                 <option value="like-icase">Contains</option>
> >>                 <option value="right-like-icase">Begins With</option>
> >>                 <option value="eq-str">Matches Exactly</option>
> >>             </input>
> >>             <input type="user" name="value0" title=""/>
> >>             <input type="hidden" name="fieldname1" value="FIN_SQ_FT"/>
> >>             <input type="select" name="operator1">
> >>                 <option value="or">OR</option>
> >>                 <option value="and">AND</option>
> >>             </input>
> >>             <input type="select" name="comparitor1" title="Having Fin.
> >> Sq.
> >> Ft. ">
> >>                 <option value="gt">Greater Than</option>
> >>                 <option value="eq">Equal To</option>
> >>                 <option value="lt">Less Than</option>
> >>             </input>
> >>             <input type="user" name="value1" title=""/>
> >>         </step>
> >>     </service>
> >>         The catalog defines how the layers will be displayed in the
> >> catalog
> >> tab.
> >>     <layer-controls>
> >>         <layer-control name="popups" service-name="popups"
> >> layer-input="layer" on="false" tip="Show Popups for %LAYER%"/>
> >>     </layer-controls>
> >>     <catalog>
> >>     <!--     <layer title="overallmap" src="parcels/parcels" status="on"
> >> popups="true" minscale="0" maxscale="150000" metadata="true" >
> >>             <metadata>http://www.aqua3.com</metadata>
> >>         </layer>
> >>         <layer title="City and County Boundaries" src="borders/all"
> >> status="on"/>
> >>         <layer title="Weather Radar" src="iastate/nexrad-n0r"
> >> status="off"
> >> legend="false"/>
> >>         <group title="Backgrounds" expand="true" multiple="false">
> >>             <layer title="Metro Base Map" src="metbase/Met Council Base
> >> Map
> >> Layers" status="on" legend="false" />
> >>             <layer title="2008 Aerial Photographs" src="lmic/fsa2008"
> >> status="off" legend="false" />
> >>             <layer title="1997 Aerial Photographs" src="lmic/bw1997"
> >>             <layer title="USGS DOQs" src="usgs_doq/DOQ" status="off"
> >> fade="true" unfade="true" legend="false" />
> >>             <layer title="USGS Topo Quads" src="usgs_drg/DRG"
> >> status="off"
> >>             <layer title="None" src=" " status="off" legend="false"
> >> fade="false" unfade="false" />
> >>         </group> -->
> >>     </catalog>
> >>         The toolbar defines which services are referneces in the toolbar
> >>     <toolbar>
> >>         <tool name="previous" title="Previous Extent" type="internal"
> >> action="previous" selectable="false"/>
> >>         <tool name="next" title="Next Extent" type="internal"
> >> action="next"
> >>         <tool name="fullextent" title="Zoom to Full Extent"
> >> type="internal"
> >> action="fullextent" selectable="false"/>
> >>         <tool name="pan" title="Pan" type="internal" action="pan"/>
> >>         <tool name="zoomin" title="Zoom In" type="internal"
> >> action="zoomin"
> >> selected="true"/>
> >>         <tool name="zoomout" title="Zoom Out" type="internal"
> >> action="zoomout"/>
> >>         <!--    <tool name="identify" title="Identify" type="service"
> >> service="identify" cursor="url('cursors/identify2.cur') 9
> >> 9,url('cursors/identify2.cur'),auto" /> -->
> >> <!--        <tool name="select" title="Select" type="service"
> >> service="select"/> -->
> >>         <!--    <tool name="buffered_select" title="Buffered Select"
> >> type="service" service="buffered_select"/> -->
> >>         <!--    <tool name="clear" title="Clear Selection"
> >> type="javascript"
> >> selectable="false">
> >>             GeoMOOSE.changeLayerVisibility('highlight/all', false);
> >>         </tool> -->
> >>         <tool name="measure" title="Measure" type="internal"
> >> action="measure"/>
> >>         <tool name="measurearea" title="Measure Area" type="internal"
> >> action="measurearea"/>
> >>         <!-- <tool name="search_parcels" title="Search Parcels"
> >> type="service" service="search_parcels" selectable="false"/> -->
> >>         <!-- <tool name="print" title="Print" type="service"
> >> service="print"
> >>         <!-- <tool name="birdseye" title="Bird's Eye View"
> >> type="service"
> >> selectable="true" service="birdseye"/> -->
> >>         <!-- <tool name="streetview" title="Google Street View"
> >> type="service" service="streetview" selectable="true"/> -->
> >>         <!-- <tool name="geocode" title="Geocode Address" type="service"
> >> service="geocode_address" selectable="true"/>  -->
> >>         <!-- <drawer>
> >>             <tool name="markup_tools" title="Sketch Tools"
> >> type="internal"
> >> action="none" selectable="false"/>
> >>             <tool name="draw_polygon" title="Draw Polygon"
> >> type="internal"
> >> action="draw_polygon"/>
> >>             <tool name="draw_line" title="Draw Line" type="internal"
> >> action="draw_line"/>
> >>             <tool name="draw_point" title="Draw Point" type="internal"
> >> action="draw_point"/>
> >>             <tool name="draw_remove" title="Remove Drawing"
> >> type="internal"
> >> action="draw_remove"/>
> >>             <tool name="draw_edit" title="Edit Drawing" type="internal"
> >> action="draw_edit_shapes"/>
> >>             <tool name="draw_edit_attributes" title="Edit Attributes"
> >> type="internal" action="draw_edit_attributes"/>
> >>             <tool name="clear_drawings" title="Clear Drawings"
> >> type="internal" action="clear_drawings" selectable="false"/>
> >>         </drawer> -->
> >>     </toolbar>
> >> </mapbook>
> >> ============= END OF MAPBOOK.XML =============
> >> I have tried getting some error reporting out of firebug with little
> >> success, if anyone can help me spot what I have done wrong it would be
> >> much
> >> appreciated and I would be happy to supply the real url's to the server
> >> off-list.
> >> Cheers
> >> Carl
> >> Protect Your Site and Customers from Malware Attacks
> >> Learn about various malware tactics and how to avoid them. Understand
> >> malware threats, the impact they can have on your business, and how you
> >> can protect your company and customers by using code signing.
> http://p.sf.net/sfu/oracle-sfdevnl_______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
> > Best Regards
> > Brent Fraser
> Best Regards
> Brent Fraser
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110114/2dc1e77c/attachment.html
More information about the Geomoose-users mailing list
