[Geomoose-users] User id
DEAN ANDERSON ANDERSON.DEAN at co.polk.or.us
Tue Jan 18 15:35:05 EST 2011
Brian
Do you want me to document this on the WIKI?
Dean
>>> Brian Fischer <bfischer at houstoneng.com> 1/18/2011 12:11 PM >>>
The code for the bookmark sessions is in the GeoMOOSE SVN trunk.  You
would have to download it and patch it in yourself or what until
GeoMOOSE 2.4 is released (not sure when).   I don’t think it is really
documented anywhere, but here is the tool definition in the mapbook.
                                                <tool name="bookmark"
title="Bookmark this Session" type="javascript" selectable="false">
GeoMOOSE.bookmark();
                                                </tool>
Brian Fischer,CFM  GIS Manager
Houston Engineering, Inc.
Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
From:Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
Sent: Tuesday, January 18, 2011 10:07 AM
To: DEAN ANDERSON
Cc: geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] User id
Hi Dean,
that sounds like it might pretty much do the job with very little
modification, is this something I can download and install.
Once again thanks to all for the responses.
Carl
On Tue, Jan 18, 2011 at 3:31 PM, DEAN ANDERSON
<ANDERSON.DEAN at co.polk.or.us> wrote:
We have a "bookmark" tool which allows users to save basic settings
such as the last selected set, mapextent and which layers are turned off
or on.  The bookmark is printed in the results tab and can be used as a
book mark, e-mailed, etc. We use this to support different groups or
individuals within the county so that their default views are saved and
accessible.   This might be modified to fit what you may need.
Dean Anderson
Polk County, Oregon
>>> Brent Fraser <bfraser at geoanalytic.com> 1/18/2011 7:25 AM >>>
Carl,
On way is to save it as a session variable in your server-side
scripting.  However if your existing site (where they log in) and your
new mapping site are on different servers, you'll need to do something
else.
Best Regards,Brent Fraser
On 1/18/2011 7:35 AM, Carl Burn wrote:
Hello all,
I have my app working in geomoose and am getting the layers working
thanks to a lot of help from the list. I have another question for the
list, again it may be a dumb one but here goes.
My users will access the app from a site that already exists and will
do so once logged in, I can pass across a user id on the url (as part of
the query string) or as a form variable. The users will then make
whatever changes to the map they need (turning layers on and off) and
save those changes, I plan to do this by saving into a database and
along with the map layer information I would need to save the user id
from the url so I can pair up users with their saved map details later
on when they are back in the main site.
Is there a recognised way to do this in geomoose or does anyone have
any suggestions.
Best
Carl
------------------------------------------------------------------------------Protect
Your Site and Customers from Malware AttacksLearn about various malware
tactics and how to avoid them. Understand malware threats, the impact
they can have on your business, and how you can protect your company and
customers by using code signing.http://p.sf.net/sfu/oracle-sfdevnl
_______________________________________________Geomoose-users mailing
listGeomoose-users at lists.sourceforge.nethttps://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110118/c9b16269/attachment.html
More information about the Geomoose-users mailing list
