[Geomoose-users] User id
Carl Burn burnsy at northcountrywoods.co.uk
Wed Jan 19 10:37:46 EST 2011
Brian,
thanks for the info, I will get right on it.
Cheers
Carl
On Tue, Jan 18, 2011 at 8:11 PM, Brian Fischer <bfischer at houstoneng.com>wrote:
>  The code for the bookmark sessions is in the GeoMOOSE SVN trunk.  You
> would have to download it and patch it in yourself or what until GeoMOOSE
> 2.4 is released (not sure when).   I don’t think it is really documented
> anywhere, but here is the tool definition in the mapbook.
>                                                 <tool name="bookmark"
> title="Bookmark this Session" type="javascript" selectable="false">
> GeoMOOSE.bookmark();
>                                                 </tool>
> *Brian Fischer,* CFM  GIS Manager
> *Houston Engineering, Inc.*
> Phone: Direct: 763-493-6664 / W: 763.493.4522 / M: 763.229.2734
> *From:* Carl Burn [mailto:burnsy at northcountrywoods.co.uk]
> *Sent:* Tuesday, January 18, 2011 10:07 AM
> *To:* DEAN ANDERSON
> *Cc:* geomoose-users at lists.sourceforge.net
> *Subject:* Re: [Geomoose-users] User id
> Hi Dean,
> that sounds like it might pretty much do the job with very little
> modification, is this something I can download and install.
> Once again thanks to all for the responses.
> Carl
> On Tue, Jan 18, 2011 at 3:31 PM, DEAN ANDERSON <
> ANDERSON.DEAN at co.polk.or.us> wrote:
> We have a "bookmark" tool which allows users to save basic settings such as
> the last selected set, mapextent and which layers are turned off or on.  The
> bookmark is printed in the results tab and can be used as a book mark,
> e-mailed, etc. We use this to support different groups or individuals within
> the county so that their default views are saved and accessible.
> This might be modified to fit what you may need.
> Dean Anderson
> Polk County, Oregon
> >>> Brent Fraser <bfraser at geoanalytic.com> 1/18/2011 7:25 AM >>>
> Carl,
> On way is to save it as a session variable in your server-side scripting.
> However if your existing site (where they log in) and your new mapping site
> are on different servers, you'll need to do something else.
> Best Regards,
> Brent Fraser
> On 1/18/2011 7:35 AM, Carl Burn wrote:
> Hello all,
> I have my app working in geomoose and am getting the layers working thanks
> to a lot of help from the list. I have another question for the list, again
> it may be a dumb one but here goes.
> My users will access the app from a site that already exists and will do so
> once logged in, I can pass across a user id on the url (as part of the query
> string) or as a form variable. The users will then make whatever changes to
> the map they need (turning layers on and off) and save those changes, I plan
> to do this by saving into a database and along with the map layer
> information I would need to save the user id from the url so I can pair up
> users with their saved map details later on when they are back in the main
> site.
> Is there a recognised way to do this in geomoose or does anyone have any
> suggestions.
> Best
> Carl
> Protect Your Site and Customers from Malware Attacks
> Learn about various malware tactics and how to avoid them. Understand
> malware threats, the impact they can have on your business, and how you
> can protect your company and customers by using code signing.
> http://p.sf.net/sfu/oracle-sfdevnl
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110119/fc9f6442/attachment.html
More information about the Geomoose-users mailing list
