[Geomoose-users] Feature editor, error missing required field
Brent Fraser bfraser at geoanalytic.com
Wed Jun 15 18:16:26 EDT 2011
Hmm.  You could try adding
required_for_create=permit_number
required_for_update=permit_number
to your Layer.ini file...  I can't see anything obvious in your files or
in editor.php...
Best Regards,
Brent Fraser
On 6/15/2011 2:43 PM, Dara Olson wrote:
> Greetings.
> I am having some problems with the feature editor setup.  When I go to
> add a point feature it says, "Missing required field:", but no field
> is listed after the error.  There seems to be no errors showing up in
> any of the logs either.  Does anyone know why I might be getting this
> error?  Below is the setup for the feature and editor.  We are running
> GeoMoose 2.2.
> Any help or suggestions would be greatly appreciated.
> Miigwech!
> Dara
> _Table:_
> CREATE TABLE permits.glifwc_permit_comments_points
>   gid serial NOT NULL,
>   file_name character varying,
>   description character varying,
>   georef_protocol character varying,
>   pdf_name character varying,
>   document_link character varying,
>   permit_number character varying,
>   the_geom900913 geometry,
>   date_lm date,
>   wbic character varying,
>   type_of_permit character varying,
>   CONSTRAINT glifwc_prior_acoe_comments_pkey PRIMARY KEY (gid),
>   CONSTRAINT enforce_dims_the_geom900913 CHECK
> (st_ndims(the_geom900913) = 2),
>   CONSTRAINT enforce_srid_the_geom900913 CHECK
> (st_srid(the_geom900913) = 900913)
> _Sequence and register:_
> A sequence was set up, permits.glifwc_permit_comments_points_gid_seq
> and an entry in the "geometry_columns" table for field
> "the_geom900913", 900913, POINT.
> _Mapfile definition:_
> LAYER # GLIFWC Permit Comments
>      NAME "glifwc_permit_comment_points"
>      TYPE POINT
>      STATUS ON
>      CONNECTIONTYPE postgis
>      CONNECTION "host=localhost dbname=xxxxx user=xxxxx password=xxxxx"
>      PROCESSING "CLOSE_CONNECTION=DEFER"
>      DATA "the_geom900913 FROM (SELECT *, ASTEXT(the_geom900913) AS
> wkt_geometry
>      FROM permits.glifwc_permit_comment_points) AS
> glifwc_permit_comment_points using unique gid using srid=900913"
>      PROJECTION
>           "init=epsg:900913"
>      END
>      TOLERANCE 6
>      CLASS
>           NAME "GLIFWC Permit Comments"
>           SYMBOL "..\..\icons\comments.gif"
>           TEMPLATE "identify.html"
>      END
>      METADATA
>           "identify_record" "identify.html"
>      END
> END # GLIFWC Permit Comments
> The layer was successfully added to the project and displays correctly.
> _Layer INI file:_
> host=localhost
> dbname=xxxxx
> username=xxxxx
> password=xxxxx
> tablename=permits.glifwc_permit_comment_points
> geometry_column=the_geom900913
> primary_key_column=gid
> primary_key_sequence=permits.glifwc_permit_comment_points_gid_seq
> srid=900913
> layerpath=glifwc_permit_comment/glifwc_permit_comment_points
> _Service:_
> <service name="add_permit_comment">
> <url>php/editor.php</url>
> <step type="spatial" name="feature:the_geom900913" line="false"
> polygon="false" point="true" default="point">
> </step>
> <step type="input">
> <input type="hidden" name="op" value="create"/>
> <input type="hidden" name="table" value="glifwc_permit_comment_points"/>
> <input type="user" name="feature:permit_number" title="Permit Number:" />
> <input type="user" name="feature:file_name" title="File Name:" />
> <input type="select" name="feature:type_of_permit" title="Type of
> Permit:">
> <option value="APM Permit">APM Permit</option>...
> </input>
> <input type="user" name="feature:wbic" title="WBIC if applicable:"/>
> <input type="user" name="feature:description" title="Description:"/>
> <input type="user" name="feature:pdf_name" title="PDF Name:"/>
> <input type="user" name="feature:document_link" title="Link to
> Document:"/>
> <input type="select" name="feature:georef_protocol"
> title="Georeference Protocol:">
> <option value="digitized by hand">Digitized by Hand</option>...
> </input>
> </step>
> </service>
> EditLive Enterprise is the world's most technically advanced content
> authoring tool. Experience the power of Track Changes, Inline Image
> Editing and ensure content is compliant with Accessibility Checking.
> http://p.sf.net/sfu/ephox-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110615/6214aaa8/attachment.html
More information about the Geomoose-users mailing list
