[Geomoose-users] Feature editor, error missing required field
dolson at glifwc.org dolson at glifwc.org
Thu Jun 16 11:45:27 EDT 2011
It worked!  I added it to the INI file and it added successfully.
Thank you so very much!
Dara
> Hmm.  You could try adding
> required_for_create=permit_number
> required_for_update=permit_number
> to your Layer.ini file...  I can't see anything obvious in your files or
> in editor.php...
> Best Regards,
> Brent Fraser
> On 6/15/2011 2:43 PM, Dara Olson wrote:
>> Greetings.
>> I am having some problems with the feature editor setup.  When I go to
>> add a point feature it says, "Missing required field:", but no field
>> is listed after the error.  There seems to be no errors showing up in
>> any of the logs either.  Does anyone know why I might be getting this
>> error?  Below is the setup for the feature and editor.  We are running
>> GeoMoose 2.2.
>> Any help or suggestions would be greatly appreciated.
>> Miigwech!
>> Dara
>> _Table:_
>> CREATE TABLE permits.glifwc_permit_comments_points
>>   gid serial NOT NULL,
>>   file_name character varying,
>>   description character varying,
>>   georef_protocol character varying,
>>   pdf_name character varying,
>>   document_link character varying,
>>   permit_number character varying,
>>   the_geom900913 geometry,
>>   date_lm date,
>>   wbic character varying,
>>   type_of_permit character varying,
>>   CONSTRAINT glifwc_prior_acoe_comments_pkey PRIMARY KEY (gid),
>>   CONSTRAINT enforce_dims_the_geom900913 CHECK
>> (st_ndims(the_geom900913) = 2),
>>   CONSTRAINT enforce_srid_the_geom900913 CHECK
>> (st_srid(the_geom900913) = 900913)
>> _Sequence and register:_
>> A sequence was set up, permits.glifwc_permit_comments_points_gid_seq
>> and an entry in the "geometry_columns" table for field
>> "the_geom900913", 900913, POINT.
>> _Mapfile definition:_
>> LAYER # GLIFWC Permit Comments
>>      NAME "glifwc_permit_comment_points"
>>      TYPE POINT
>>      STATUS ON
>>      CONNECTIONTYPE postgis
>>      CONNECTION "host=localhost dbname=xxxxx user=xxxxx password=xxxxx"
>>      PROCESSING "CLOSE_CONNECTION=DEFER"
>>      DATA "the_geom900913 FROM (SELECT *, ASTEXT(the_geom900913) AS
>> wkt_geometry
>>      FROM permits.glifwc_permit_comment_points) AS
>> glifwc_permit_comment_points using unique gid using srid=900913"
>>      PROJECTION
>>           "init=epsg:900913"
>>      END
>>      TOLERANCE 6
>>      CLASS
>>           NAME "GLIFWC Permit Comments"
>>           SYMBOL "..\..\icons\comments.gif"
>>           TEMPLATE "identify.html"
>>      END
>>      METADATA
>>           "identify_record" "identify.html"
>>      END
>> END # GLIFWC Permit Comments
>> The layer was successfully added to the project and displays correctly.
>> _Layer INI file:_
>> host=localhost
>> dbname=xxxxx
>> username=xxxxx
>> password=xxxxx
>> tablename=permits.glifwc_permit_comment_points
>> geometry_column=the_geom900913
>> primary_key_column=gid
>> primary_key_sequence=permits.glifwc_permit_comment_points_gid_seq
>> srid=900913
>> layerpath=glifwc_permit_comment/glifwc_permit_comment_points
>> _Service:_
>> <service name="add_permit_comment">
>> <url>php/editor.php</url>
>> <step type="spatial" name="feature:the_geom900913" line="false"
>> polygon="false" point="true" default="point">
>> </step>
>> <step type="input">
>> <input type="hidden" name="op" value="create"/>
>> <input type="hidden" name="table" value="glifwc_permit_comment_points"/>
>> <input type="user" name="feature:permit_number" title="Permit Number:"
>> <input type="user" name="feature:file_name" title="File Name:" />
>> <input type="select" name="feature:type_of_permit" title="Type of
>> Permit:">
>> <option value="APM Permit">APM Permit</option>...
>> </input>
>> <input type="user" name="feature:wbic" title="WBIC if applicable:"/>
>> <input type="user" name="feature:description" title="Description:"/>
>> <input type="user" name="feature:pdf_name" title="PDF Name:"/>
>> <input type="user" name="feature:document_link" title="Link to
>> Document:"/>
>> <input type="select" name="feature:georef_protocol"
>> title="Georeference Protocol:">
>> <option value="digitized by hand">Digitized by Hand</option>...
>> </input>
>> </step>
>> </service>
>> EditLive Enterprise is the world's most technically advanced content
>> authoring tool. Experience the power of Track Changes, Inline Image
>> Editing and ensure content is compliant with Accessibility Checking.
>> http://p.sf.net/sfu/ephox-dev2dev
>> Geomoose-users mailing list
>> Geomoose-users at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
