[Geomoose-users] feature editing - able to add polygons, not able to delete or edit.
Atif Butt matifbutt at gmail.com
Tue Nov 22 16:03:44 EST 2011
for further investigation, the mapfile defined inside this tag not loading
as a layer, and outcome become pink background
<map-source name="poly_editor" type="mapserver">
        <file>./development/test_polygons/test_polygons.map</file>
        <layer name="polygons"/>
</map-source>
my map file is bellow:
MAP
SIZE 400 400
EXTENT 427632.500000 4893613.330000 560300.922104 5015936.680000
UNITS METERS
SYMBOLSET '../symbols/symbol.sym'
STATUS ON
TRANSPARENT TRUE
LAYER
NAME 'polygons'
TYPE POLYGON
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION 'host=localhost dbname=postgis user=postgres password=abcd1234'
DATA 'wkb_geometry from (select polygon_id, title, owner,
astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as
mytable using unique polygon_id'
CLASS
STYLE
SYMBOL 'circle'
OUTLINECOLOR 255 255 0
SIZE 10
END
END
METADATA
'identify_record' 'identify.html'
END
END
END
Any suggestion
Atif
On Tue, Nov 22, 2011 at 1:29 PM, Atif Butt <matifbutt at gmail.com> wrote:
> when I click on checkbox "Editing Layers - > polygons"  it isnot showing
> up anything except a pink blank layer as shown in the figure (add polygon
> 3-4).
> It seems to me that polygon layer is not adding properly.
> In steps Add polygon 1-2, my database storing the values in test_polygons
> table.
> Regards
> Atif
> On Tue, Nov 22, 2011 at 10:18 AM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>>  It looks like Geomoose is having trouble rendering the layer.  What
>> does your browser's debugger show is returned when that layer is turned on?
>> Best Regards,
>> Brent Fraser
>> On 11/21/2011 11:54 PM, Atif Butt wrote:
>> Hi All
>> I have performed all the steps described for feature editor. I havent got
>> any result back, except blank layer (as shown in pictures "add polygon 1 -
>> 4")
>> Kindly if anybody have solved this probelm then let me know.
>> Regards
>> Atif
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111122/b313aafc/attachment.html
More information about the Geomoose-users mailing list
