[Geomoose-users] feature editing - able to add polygons, not able to delete or edit.
Dan Little danlittle at yahoo.com
Tue Nov 29 13:37:50 EST 2011
Using firefox, get the pink screen to happen.
Goto Tools -> Page Info, click on the media tab.
Scroll until you find the entry calling mapserver with your mapfile.  Open that into a new tab, then check what error it displays.  If you can diagnose that error, then great. If you cannot, post the error here.
>________________________________
> From: Atif Butt <matifbutt at gmail.com>
>To: Brent Fraser <bfraser at geoanalytic.com>; danlittle at yahoo.com
>Cc: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Tuesday, November 22, 2011 3:03 PM
>Subject: Re: [Geomoose-users] feature editing - able to add polygons, not able to delete or edit.
>for further investigation, the mapfile defined inside this tag not loading as a layer, and outcome become pink background
><map-source name="poly_editor" type="mapserver">
>        <file>./development/test_polygons/test_polygons.map</file>
>        <layer name="polygons"/>
></map-source>
>my map file is bellow:
>MAP
>SIZE 400 400
>EXTENT  427632.500000 4893613.330000 560300.922104 5015936.680000
>UNITS METERS
>SYMBOLSET '../symbols/symbol.sym'
>STATUS ON
>TRANSPARENT TRUE
>LAYER
>NAME 'polygons'
>TYPE POLYGON
>STATUS ON
>CONNECTIONTYPE POSTGIS
>CONNECTION 'host=localhost dbname=postgis user=postgres password=abcd1234'
>DATA 'wkb_geometry from (select polygon_id, title, owner, astext(wkb_geometry) as wkt_geometry, wkb_geometry from test_polygons) as mytable using unique polygon_id'
>CLASS
>STYLE
>SYMBOL 'circle'
>OUTLINECOLOR 255 255 0
>SIZE 10
>END
>END
>METADATA
>'identify_record' 'identify.html'
>END
>END
>END
>Any suggestion
>Atif
>On Tue, Nov 22, 2011 at 1:29 PM, Atif Butt <matifbutt at gmail.com> wrote:
>when I click on checkbox "Editing Layers - > polygons"  it isnot showing up anything except a pink blank layer as shown in the figure (add polygon 3-4).
>>It seems to me that polygon layer is not adding properly.
>>In steps Add polygon 1-2, my database storing the values in test_polygons table.
>>Regards
>>Atif
>>On Tue, Nov 22, 2011 at 10:18 AM, Brent Fraser <bfraser at geoanalytic.com> wrote:
>>It looks like Geomoose is having trouble rendering the layer.  What  does your browser's debugger show is returned when that layer is turned on?
>>>Best Regards,
Brent Fraser
>>>On 11/21/2011 11:54 PM, Atif Butt wrote:
>>>Hi All
>>>>I have performed all the steps described for feature editor. I havent got any result back, except blank layer (as shown in pictures "add polygon 1 - 4")
>>>>Kindly if anybody have solved this probelm then let me know.
>>>>Regards
>>>>Atif
>>>>_______________________________________________
Geomoose-users mailing list Geomoose-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111129/d6d698e8/attachment.html
More information about the Geomoose-users mailing list
