[Geomoose-users] label placement for polygons
Ed Boesenberg, III eboesenberg at niraengineers.com
Tue Oct 25 16:36:08 EDT 2011
You need to change the data type within the map file to "line" and it will
label it like a  line segment and not a polygon.  If you have some type of
shading or fill pattern you need an additional layer with those polygon
styles specified.
Ed Boesenberg, III
CADD / GIS Manager
NIRA Consulting Engineers, Inc.
950 Fifth Avenue
Coraopolis, PA 15108
www.niraengineers.com
T: 412-262-3970
F: 412-262-1938
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Tuesday, October 25, 2011 4:23 PM
To: Jim Dahl
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] label placement for polygons
Jim,
  Labeling is a mapserver function.  Does using POSITION CC in the LABEL
object in the map file help move the label away from the edge?
Best Regards,
Brent Fraser
On 10/25/2011 12:00 PM, Jim Dahl wrote:
Any suggestions for labeling away from the edge when the polygon is "L"
shaped.  It apparently goes to the center of the bounding box and I would
like it to buffer from the edge of the polygon.  I do not see anything in
the label class documentation.
Thanks,
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
526 Willow Dr
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-762-2999
F 320-762-2998
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111025/533bd28b/attachment-0001.html
More information about the Geomoose-users mailing list
