[Geomoose-users] label placement for polygons
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Tue Oct 25 16:41:20 EDT 2011
Thanks all, yes I was looking at the Mapserver documentation and struck out.
*         I currently have the polygons as TYPE LINE.
*         I also tried to change the TYPE ANNOTATION to line and it bombs out.
*         Position was at CC but in case of L shaped polys or two part polys, it does not label very good, because it uses bounding box.
*         POSITION AUTO works good for L shaped polys but too many labels cross the parcel boundary.
*         It would help if ANGLE FOLLOW would work but all labels are horizontal.
Suggestions are...
Jim
From: Ed Boesenberg, III [mailto:eboesenberg at niraengineers.com]
Sent: Tuesday, October 25, 2011 3:36 PM
To: 'Brent Fraser'; Jim Dahl
Cc: geomoose-users at lists.osgeo.org
Subject: RE: [Geomoose-users] label placement for polygons
You need to change the data type within the map file to "line" and it will label it like a  line segment and not a polygon.  If you have some type of shading or fill pattern you need an additional layer with those polygon styles specified.
Ed Boesenberg, III
CADD / GIS Manager
NIRA Consulting Engineers, Inc.
950 Fifth Avenue
Coraopolis, PA 15108
eboesenberg at niraengineers.com<mailto:eboesenberg at niraengineers.com>
www.niraengineers.com<http://www.niraengineers.com>
T: 412-262-3970
F: 412-262-1938
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Tuesday, October 25, 2011 4:23 PM
To: Jim Dahl
Subject: Re: [Geomoose-users] label placement for polygons
Jim,
  Labeling is a mapserver function.  Does using POSITION CC in the LABEL object in the map file help move the label away from the edge?
Best Regards,
Brent Fraser
On 10/25/2011 12:00 PM, Jim Dahl wrote:
Any suggestions for labeling away from the edge when the polygon is "L" shaped.  It apparently goes to the center of the bounding box and I would like it to buffer from the edge of the polygon.  I do not see anything in the label class documentation.
Thanks,
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
526 Willow Dr
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-762-2999
F 320-762-2998
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111025/e6bb1822/attachment.html
More information about the Geomoose-users mailing list
