[Geomoose-users] label placement for polygons
Brent Fraser bfraser at geoanalytic.com
Tue Oct 25 17:08:49 EDT 2011
Jim,
   I had some thoughts wrt to polygon labeling a few months ago
(http://osgeo-org.1803224.n2.nabble.com/Rendering-Challenges-Polygon-labeling-td6348194.html,
and
http://lists.osgeo.org/pipermail/mapserver-users/2011-May/068731.html)
but I haven't done anything about it.  Perhaps if we get enough support
on the mapserver list, or some funding, things might improve...
Best Regards,
Brent Fraser
On 10/25/2011 2:41 PM, Jim Dahl wrote:
> Thanks all, yes I was looking at the Mapserver documentation and
> struck out.
> ·I currently have the polygons as TYPE LINE.
> ·I also tried to change the TYPE ANNOTATION to line and it bombs out.
> ·Position was at CC but in case of L shaped polys or two part polys,
> it does not label very good, because it uses bounding box.
> ·POSITION AUTO works good for L shaped polys but too many labels cross
> the parcel boundary.
> ·It would help if ANGLE FOLLOW would work but all labels are horizontal.
> Suggestions are...
> Jim
> *From:*Ed Boesenberg, III [mailto:eboesenberg at niraengineers.com]
> *Sent:* Tuesday, October 25, 2011 3:36 PM
> *To:* 'Brent Fraser'; Jim Dahl
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* RE: [Geomoose-users] label placement for polygons
> You need to change the data type within the map file to "line" and it
> will label it like a  line segment and not a polygon.  If you have
> some type of shading or fill pattern you need an additional layer with
> those polygon styles specified.
> Ed Boesenberg, III
> CADD / GIS Manager
> NIRA Consulting Engineers, Inc.
> 950 Fifth Avenue
> Coraopolis, PA 15108
> eboesenberg at niraengineers.com <mailto:eboesenberg at niraengineers.com>
> www.niraengineers.com <http://www.niraengineers.com>
> T: 412-262-3970
> F: 412-262-1938
> *From:*geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Brent
> Fraser
> *Sent:* Tuesday, October 25, 2011 4:23 PM
> *To:* Jim Dahl
> *Subject:* Re: [Geomoose-users] label placement for polygons
> Jim,
>   Labeling is a mapserver function.  Does using POSITION CC in the
> LABEL object in the map file help move the label away from the edge?
> Best Regards,
> Brent Fraser
> On 10/25/2011 12:00 PM, Jim Dahl wrote:
> Any suggestions for labeling away from the edge when the polygon is
> "L" shaped.  It apparently goes to the center of the bounding box and
> I would like it to buffer from the edge of the polygon.  I do not see
> anything in the label class documentation.
> Thanks,
> Jim Dahl, GISP
> GIS Coordinator
> Douglas County Public Works
> 526 Willow Dr
> PO Box 398
> Alexandria MN 56308
> V 320-762-2933
>    320-762-2999
> F 320-762-2998
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111025/b02ca133/attachment-0001.html
More information about the Geomoose-users mailing list
