[Geomoose-users] Using the feature editor with multiple layers
Ed Boesenberg, III boesiii at yahoo.com
Fri Oct 28 16:23:36 EDT 2011
I figured out the first part, I had the wrong name for the layer but for
some reason it didn't throw pink screen.
I am still wondering about the INI files.  Any thoughts?
Ed
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Ed Boesenberg,
III
Sent: Friday, October 28, 2011 3:03 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Using the feature editor with multiple layers
I was trying to setup a second layer for editing but I was unable to get it
to display.  I setup my first layer using the example on the geomoose
website and I got it to work.  When I try to add a new feature (polygon) it
goes thru the process and states it added a feature to the database but when
I go back to the layer catalog and refresh the layer, nothing shows up.  Why
would it not show up?  Could it be a projection issue (not sure how since I
copied items from the example)? Are you able to setup multiple layers for
editing in GM 2.4?
Also, why do the INI files need to be in folder "conf\editor"?  I tried to
put INI files in the same folder as the MAP file, as per the website
example, but GM did not like that.  Is there a configuration file somewhere?
Thanks,
Ed
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111028/592c571c/attachment.html
More information about the Geomoose-users mailing list
