[Geomoose-users] Using the feature editor with multiple layers
Brent Fraser bfraser at geoanalytic.com
Fri Oct 28 18:05:40 EDT 2011
Hmmm.  The Feature Editor docs say
"All of the .INI files are stored in GeoMOOSE's "config/editor" folder.
As I recall the PHP scripts need to read the INI files so it assumes
they're in ..\conf\editor
Best Regards,
Brent Fraser
On 10/28/2011 2:23 PM, Ed Boesenberg, III wrote:
> I figured out the first part, I had the wrong name for the layer but
> for some reason it didn't throw pink screen.
> I am still wondering about the INI files.  Any thoughts?
> Ed
> *From:*geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Ed
> Boesenberg, III
> *Sent:* Friday, October 28, 2011 3:03 PM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* [Geomoose-users] Using the feature editor with multiple layers
> I was trying to setup a second layer for editing but I was unable to
> get it to display.  I setup my first layer using the example on the
> geomoose website and I got it to work.  When I try to add a new
> feature (polygon) it goes thru the process and states it added a
> feature to the database but when I go back to the layer catalog and
> refresh the layer, nothing shows up.  Why would it not show up?  Could
> it be a projection issue (not sure how since I copied items from the
> example)? Are you able to setup multiple layers for editing in GM 2.4?
> Also, why do the INI files need to be in folder "conf\editor"?  I
> tried to put INI files in the same folder as the MAP file, as per the
> website example, but GM did not like that.  Is there a configuration
> file somewhere?
> Thanks,
> Ed
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20111028/b7c21d65/attachment.html
More information about the Geomoose-users mailing list
