[Geomoose-users] Adding GeoRSS to GeoMoose application
Eli Adam EAdam at co.lincoln.or.us
Mon Sep 26 16:15:38 EDT 2011
Dara,
GeoRSS is a supported ogr format, http://gdal.org/ogr/drv_georss.html
I've not used or tested this specifically, but am under the impression that MapServer can be set to use gdal/ogr as data source then if ogr can read the GeoRSS.  Then you can put the GeoRSS as a mapserv or wms source in a GeoMOOSE application just like any other.
More about ogr datasources in mapserver, here, http://mapserver.org/input/vector/ogr.html
HTH, Eli
>>> On 9/26/2011 at 12:49 PM, in message
<F2C914F542434D6E8FB86177241E80A5 at GISWKSTN2>, "Dara Olson" <dolson at glifwc.org>
wrote:
> Has anyone added a GeoRSS layer to a GeoMoose application?  If so, I would be
> grateful for any examples, ideas, tips, etc. on how to setup.
> Thanks!
> Dara
More information about the Geomoose-users mailing list
