[Geomoose-users] Adding GeoRSS to GeoMoose application
TC Haddad tchaddad at gmail.com
Mon Sep 26 18:09:13 EDT 2011
I've used some really big GeoRss files directly in OpenLayers (skipping
Mapserver), but I assume it would work through a map file as well. I can
test my layer and let you know.
Isn't that all that would be required for GeoMoose to work as well? to have
a working map file for the layer?
Tanya
On Mon, Sep 26, 2011 at 1:15 PM, Eli Adam <EAdam at co.lincoln.or.us> wrote:
> Dara,
> GeoRSS is a supported ogr format, http://gdal.org/ogr/drv_georss.html
> I've not used or tested this specifically, but am under the impression that
> MapServer can be set to use gdal/ogr as data source then if ogr can read the
> GeoRSS.  Then you can put the GeoRSS as a mapserv or wms source in a
> GeoMOOSE application just like any other.
> More about ogr datasources in mapserver, here,
> http://mapserver.org/input/vector/ogr.html
> HTH, Eli
> >>> On 9/26/2011 at 12:49 PM, in message
> <F2C914F542434D6E8FB86177241E80A5 at GISWKSTN2>, "Dara Olson" <
> dolson at glifwc.org>
> wrote:
> > Has anyone added a GeoRSS layer to a GeoMoose application?  If so, I
> would be
> > grateful for any examples, ideas, tips, etc. on how to setup.
> > Thanks!
> > Dara
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110926/dfd2e280/attachment.html
More information about the Geomoose-users mailing list
