[Geomoose-users] Adding GeoRSS to GeoMoose application
Dan Little danlittle at yahoo.com
Tue Sep 27 08:53:14 EDT 2011
Yep, a working Mapfile for the layer would work.  OGR is the easiest way to go with MapServer.
GM 2.6's new MapSource structure should make it easier to add support for GeoRSS as a layer type but we're just looking at a developer release at the end of the week. (Not an RC or anything as we need to radically update the docs.)
>________________________________
>From: TC Haddad <tchaddad at gmail.com>
>To: Eli Adam <EAdam at co.lincoln.or.us>
>Cc: Dara Olson <dolson at glifwc.org>; Geomoose-users at lists.osgeo.org
>Sent: Monday, September 26, 2011 5:09 PM
>Subject: Re: [Geomoose-users] Adding GeoRSS to GeoMoose application
>I've used some really big GeoRss files directly in OpenLayers (skipping Mapserver), but I assume it would work through a map file as well. I can test my layer and let you know.
>Isn't that all that would be required for GeoMoose to work as well? to have a working map file for the layer?
>Tanya
>On Mon, Sep 26, 2011 at 1:15 PM, Eli Adam <EAdam at co.lincoln.or.us> wrote:
>Dara,
>>GeoRSS is a supported ogr format, http://gdal.org/ogr/drv_georss.html
>>I've not used or tested this specifically, but am under the impression that MapServer can be set to use gdal/ogr as data source then if ogr can read the GeoRSS.  Then you can put the GeoRSS as a mapserv or wms source in a GeoMOOSE application just like any other.
>>More about ogr datasources in mapserver, here, http://mapserver.org/input/vector/ogr.html
>>HTH, Eli
>>>>> On 9/26/2011 at 12:49 PM, in message
>><F2C914F542434D6E8FB86177241E80A5 at GISWKSTN2>, "Dara Olson" <dolson at glifwc.org>
>>wrote:
>>> Has anyone added a GeoRSS layer to a GeoMoose application?  If so, I would be
>>> grateful for any examples, ideas, tips, etc. on how to setup.
>>> Thanks!
>>> Dara
>>_______________________________________________
>>Geomoose-users mailing list
>>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110927/2c9d0483/attachment.html
More information about the Geomoose-users mailing list
