[Geomoose-users] Adding GeoRSS to GeoMoose application
Dara Olson dolson at glifwc.org
Tue Sep 27 13:23:57 EDT 2011
Thanks! It looks like the version of ms4w that we are using does not have the OGR library with GeoRSS capabilities so we need to work on that first.
Thanks again for the help.
Dara
  ----- Original Message -----
  To: TC Haddad ; Eli Adam
  Cc: Dara Olson ; Geomoose-users at lists.osgeo.org
  Sent: Tuesday, September 27, 2011 7:53 AM
  Subject: Re: [Geomoose-users] Adding GeoRSS to GeoMoose application
  Yep, a working Mapfile for the layer would work.  OGR is the easiest way to go with MapServer.
  GM 2.6's new MapSource structure should make it easier to add support for GeoRSS as a layer type but we're just looking at a developer release at the end of the week. (Not an RC or anything as we need to radically update the docs.)
    To: Eli Adam <EAdam at co.lincoln.or.us>
    Cc: Dara Olson <dolson at glifwc.org>; Geomoose-users at lists.osgeo.org
    Sent: Monday, September 26, 2011 5:09 PM
    I've used some really big GeoRss files directly in OpenLayers (skipping Mapserver), but I assume it would work through a map file as well. I can test my layer and let you know.
    Isn't that all that would be required for GeoMoose to work as well? to have a working map file for the layer?
    Tanya
    On Mon, Sep 26, 2011 at 1:15 PM, Eli Adam <EAdam at co.lincoln.or.us> wrote:
      Dara,
      GeoRSS is a supported ogr format, http://gdal.org/ogr/drv_georss.html
      I've not used or tested this specifically, but am under the impression that MapServer can be set to use gdal/ogr as data source then if ogr can read the GeoRSS.  Then you can put the GeoRSS as a mapserv or wms source in a GeoMOOSE application just like any other.
      More about ogr datasources in mapserver, here, http://mapserver.org/input/vector/ogr.html
      HTH, Eli
      >>> On 9/26/2011 at 12:49 PM, in message
      <F2C914F542434D6E8FB86177241E80A5 at GISWKSTN2>, "Dara Olson" <dolson at glifwc.org>
      wrote:
      > Has anyone added a GeoRSS layer to a GeoMoose application?  If so, I would be
      > grateful for any examples, ideas, tips, etc. on how to setup.
      > Thanks!
      > Dara
      Geomoose-users mailing list
      http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20110927/952c6670/attachment-0001.html
More information about the Geomoose-users mailing list
