[Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
Brian Fischer bfischer at houstoneng.com
Tue Apr 24 09:06:41 EDT 2012
There are a few more steps you have to take if you are going to change the projection.  Here is a basic list.
1)      Create a new Proj4js projection definition and put it in htdocs/projections
2)      In geomoose.html make sure you have a reference to that projection.  You should see a couple other in there now for 3857
3)      Change the projection in conf/settings.ini
4)      Change the projection in conf/mapbook.xml
This should be all you need to do.
Brian Fischer, CFM
GIS Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
Sent: Monday, April 23, 2012 3:27 PM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
I downloaded the latest nightly to get familiar with release 2.6.  I'm afraid I didn't get very far before the dreaded Pink Screen.  This happened when editing mapbook.xml, about line 11.  The parameter is the projection, EPSG:3857.  My data is in EPSG:26919.  If I change that line to 26919, the map screen goes pink.  I can't find any errors in Firebug or the error.txt.  Any suggestions?
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120424/9764ae49/attachment.html
More information about the Geomoose-users mailing list
