[Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
Dan Little danlittle at yahoo.com
Tue Apr 24 09:23:01 EDT 2012
YOU SHOULD NEVER CHANGE ANY SETTINGS IN "settings.ini"  .
ONLY CHANGE SETTINGS IN "local_settings.ini"  ANY SETTING IN "local_settings.ini" WILL OVERRIDE A SETTING IN "settings.ini"
You have been warned.
>________________________________
> From: Brian Fischer <bfischer at houstoneng.com>
>To: "Bistrais, Bob" <Bob.Bistrais at maine.gov>; "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Tuesday, April 24, 2012 8:06 AM
>Subject: RE: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>There are a few more steps you have to take if you are going to change the projection.  Here is a basic list.
>1)      Create a new Proj4js projection definition and put it in htdocs/projections
>2)      In geomoose.html make sure you have a reference to that projection.  You should see a couple other in there now for 3857
>3)      Change the projection in conf/settings.ini
>4)      Change the projection in conf/mapbook.xml
>This should be all you need to do.
>Brian Fischer, CFM
>GIS Manager
>Houston Engineering, Inc.
>O763.493.4522 | D 763.493.6664 | M 763.229.2734
>From:geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Bistrais, Bob
>Sent: Monday, April 23, 2012 3:27 PM
>To: geomoose-users at lists.osgeo.org
>Subject: [Geomoose-users] problem setting up mapbook.xml in 2.6- projection issue
>I downloaded the latest nightly to get familiar with release 2.6.  I’m afraid I didn’t get very far before the dreaded Pink Screen.  This happened when editing mapbook.xml, about line 11.  The parameter is the projection, EPSG:3857.  My data is in EPSG:26919.  If I change that line to 26919, the map screen goes pink.  I can’t find any errors in Firebug or the error.txt.  Any suggestions?
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120424/8c275a4b/attachment.html
More information about the Geomoose-users mailing list
