[Geomoose-users] Cant get the demo data to work
Brent Fraser bfraser at geoanalytic.com
Tue Jan 17 13:35:56 EST 2012
For others trying the same thing, here are the steps:
1.  Install MS4W 2.3.1
2.  GeoMoose 2.4 for MS4W - Web merc
3.  Restart Apache
         (using I.E, the site will show the html only)
4.  Edit compiled.js, line 2217: remove trailing ","
         (now will show icons, but no catalog)
5.  Edit geommose.html: uncomment Yahoo, Google, Bing APIs
         (now will show all Geomoose components)
6.  Get Google API key from Google
Best Regards,
Brent Fraser
On 1/17/2012 10:42 AM, William Lavell wrote:
> Sweet got it. Just had to restart appache
> -----Original Message-----
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Monday, January 16, 2012 4:29 PM
> To: William Lavell
> Cc: GeoMOOSE Users List
> Subject: Re: [Geomoose-users] Cant get the demo data to work
> I think the combination you have is good (and at this point, the recommended one).
> You need to un-comment (take out the<!-- and -->)the various web API references in geomoose
> Change this:
> <!-- these are the mapping libraries -->
> <script type="text/javascript"
> src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1'></script>
> src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAQIpq5I8azu0hKAMlTu1zmxQYDK6MPyH5GZ5Hq2PBnNsY7_-W1RSUC_OBwhEbX_tFDnrJ9Rk-Jr1JYQ"></script>
> src="http://api.maps.yahoo.com/ajaxymap?v=3.0&appid=euzuro-openlayers"></script>
> to
> Best Regards,
> Brent Fraser
> On 1/16/2012 4:50 PM, William Lavell wrote:
>> When you installed geomoose did it work out of the box? Maybe I can just use the versions you used.
>> Sent: Monday, January 16, 2012 3:47 PM
>> To: William Lavell
>> No, the browser color codes the html source green for comments, blue for links, black for everything else (as far as I know).
>> Best Regards,
>> Brent Fraser
>> On 1/16/2012 4:38 PM, William Lavell wrote:
>>> I went to the firebug tool and clicked on view generated source and it produced the following document. The bottom part of scripts were not colored or highlighted as the start was. Does this indicate an issue with the scripts as they are not being recognized?
>>> Sent: Saturday, January 14, 2012 8:49 AM
>>> To: William Lavell
>>>       I think Eli gave some good advice in reply to your email on Jan 3.
>>> But to make sure I'm on the right track to solve your problem, I need some more info on your configuration:
>>> Server O/S:     ?
>>> MS4W version:      ?
>>> GeoMoose:    v2.4
>>> Browser:    Firefox v?
>>> Thanks!
>>> Best Regards,
>>> Brent Fraser
>>> On 1/13/2012 4:25 PM, William Lavell wrote:
>>>> Hi so how do you suppose I can begin to solve this issue.  Where
>>>> should the correct projection be? It is odd how I installed it
>>>> exactly as the documentation states I should but nothing seems to be coming.
>>>> Where should my data be located?  How can I find the EPSG file?
>>>> Sent: Monday, January 02, 2012 9:15 AM
>>>> To: William Lavell
>>>> Cc: geomoose-users at lists.osgeo.org
>>>> William,
>>>>       The fact that the buttons are rendered means the map book is
>>>> being sent by the sever-side scripting and parsed ok by the client-side javascript.
>>>>      Since  the map area is white and not a pink broken-image icon,
>>>> mapserver is returning an image (I think); it just isn't rendering
>>>> any the the data into it.  Typically this means the data is not
>>>> accessible (security, path problems, etc), or there's a projection
>>>> problem (eg it can't find
>>>> EPSG:900913 in the epsg file).  I'd have to check past emails, but I
>>>> think you have the epsg problem....
>>>> Best Regards,
>>>> Brent Fraser
>>>>> Hi I was wondering if there is a read me or help file that can
>>>>> explain the default settings I should use when setting up geomoose.
>>>>> I unzipped all the packages to the c: drive on my computer and
>>>>> installed geomoose as well as the c: drive.
>>>>> I have checked and apache is working and so is map server
>>>>> When I go to http://localhost/geomoose2/geomoose.html
>>>>> it seems to work and geomoose opens but there is no data in there.
>>>>> The html template is there and so are the tools and buttons on the
>>>>> top as is the zoom and the ability to see the coordinates however....
>>>>> The screen is blank There is nothing in it.
>>>>> It seems that perhaps it is not reading the mapbook xml document.
>>>>> Is it an issue with perhaps using python 2.4 as opposed to 2.5  ?
>>>>> Any help would be awesome.
>>>>> It seems like a great programme once I can get it to work. The HTML
>>>>> side of things seems to work but just getting the scripts to
>>>>> actually start loading the data are not working.
>>>>> Here is print screen as well
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
