[Geomoose-users] Data Projected in wrong area
Brent Fraser bfraser at geoanalytic.com
Fri Jul 13 08:39:00 PDT 2012
Which version of GM and MS4W?  And the Feature Report saw working before
the coordinate system changes?
Best Regards,
Brent Fraser
On 7/13/2012 9:27 AM, Joshua Meyer wrote:
> My data is not being projected in the correct location.  However,
> Feature_Report is no longer working correctly.  The parcels are no longer
> showing in the report after using the identify tool.  All the information I
> am wanting is displaying currently but the parcel image is not present.
> Deputy Joshua Meyer #198
> Lafayette County Sheriff's Department GIS
> 107 S. 11th Street
> Lexington Mo, 64067
> Phone: (660) 259-2796 | Fax: (660) 259-2545
> Cell: (660) 259-1234
> -----Original Message-----
> From: geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Joshua Meyer
> Sent: Thursday, July 12, 2012 10:21 AM
> To: 'Brent Fraser'
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Data Projected in wrong area
> Thank you very much!  That fixed it!
> Joshua Meyer
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Thursday, July 12, 2012 10:04 AM
> To: Joshua Meyer
> Joshua,
>       From your posts, I assume you want to display the data in EPSG:3857 to
> allow overlaying your data on to Google/Bing/Yahoo map layers?  And your
> data is currently stored in NAD_1983_StatePlane_Missouri_West_FIPS_2403_
> **Feet** which (according to SpatialReference) is not defined by EPSG, but
> is defined by ESRI.
> EPSG does define the State Plane zone with units of meters, EPSG:26998, but
> that won't help.
> So the only part of the configuration that needs to define the State plane
> zone is in the LAYER's PROJECTION object (it specifies the coordinate system
> of the source data).  The MAP's PROJECTION object needs to define the target
> coordinate system (EPSG:3857) as mapserver will handle the re-projection
> from the source system to the target system.  And the GeoMoose needs only to
> be configured for EPSG:3857 since there is no need for it to know about the
> coordinate system of the source data.
> In your Mapserver map file, the LAYER should have
> LAYER
>       PROJECTION
>           'init=esri:102698'
>       END
> (note the esri, not epsg as the defining authority).  And the MAP object
> should have
> MAP
>       PROJECTION
>           'init=epsg:3857'
>       END
> Best Regards,
> Brent Fraser
> On 7/12/2012 8:30 AM, Joshua Meyer wrote:
>> I may not totally understand your question.  Here is the Projection
>> from one of the map files.
>> 	WEB
>> 		METADATA
>> 			'ows_title' 'County'
>> 			'ows_srs' 'EPSG:102698 EPSG:26998 EPSG:26915
>> EPSG:4326 EPSG:900913 EPSG:3857'
>> 			'ows_enable_request' '*'
>> 		END
>> 	END
>> 	PROJECTION
>> 		'init=epsg:26998'
>> 	END
>> I have added the projection to the geomoose.html file.
>> 	<script type="text/javascript"
>> src="projections/EPSG26998.js"></script>
>> Here is the projection file as I copied off of spatialreference.
>> 	Proj4js.defs["EPSG:26998"] = "+proj=tmerc +lat_0=36.16666666666666
>> +lon_0=-94.5 +k=0.999941177 +x_0=850000 +y_0=0 +ellps=GRS80
>> ++datum=NAD83 units=m +no_defs";
>> 107 S. 11th Street
>> Lexington Mo, 64067
>> Sent: Thursday, July 12, 2012 9:18 AM
>> To: Joshua Meyer
>> So what does your Mapserver mapfile contain in terms of projections?
>> Best Regards,
>> Brent Fraser
>> On 7/12/2012 8:08 AM, Joshua Meyer wrote:
>>> I have performed all those steps.  If I leave the projection in
>>> mapbook.xml as 3857 my data is projected off the coast of Maine and
>> rotated clockwise.
>>> The map files I created(modified) are initialized as 26998.  The
>>> settings.ini and mapbook.xml are both 3857. I have changed the
>>> projection in settings.ini to 26998 and this has no effect on how my
>>> data
>> is projected.
>>> Joshua Meyer
>>> From: TC Haddad [mailto:tchaddad at gmail.com]
>>> Sent: Tuesday, July 10, 2012 3:56 PM
>>> To: Joshua Meyer
>>> Make sure to look closely at:
>>> http://www.geomoose.org/docs/projections.html
>>> In particular, both parts of Step 2.
>>> Tanya
>>> On Tue, Jul 10, 2012 at 12:03 PM, Joshua Meyer <jmeyer at lcsheriff.com>
>> wrote:
>>>> I am new to GeoMoose.  I have added my data and have it projecting.
>>>> The data is all NAD_1983_StatePlane_Missouri_West_FIPS_2403_Feet.  I
>>>> looked up the information on spatialreference.com and found I needed
>>>> EPSG:26998.  I added the new EPSG as per the GeoMoose instructions
>>>> on http://www.geomoose.org/docs/projections.html.
>>>> My data is being projected over Africa.  Does anyone know what I am
>>>> doing wrong?
>>>> Thanks,
>>>> Josh
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
