[Geomoose-users] Data Projected in wrong area
Joshua Meyer jmeyer at lcsheriff.com
Fri Jul 13 10:32:38 PDT 2012
Feature Report was working before the coordinate system changes.  I have the
pdf's of the report and jpg of the parcel in the ms_tmp folder.  I am using
GeoMoose 2.6 and MS4W 3.0.6.
Deputy Joshua Meyer #198
Lafayette County Sheriff's Department GIS
107 S. 11th Street
Lexington Mo, 64067
Phone: (660) 259-2796 | Fax: (660) 259-2545
Cell: (660) 259-1234
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Friday, July 13, 2012 10:39 AM
To: Joshua Meyer
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Data Projected in wrong area
Which version of GM and MS4W?  And the Feature Report saw working before the
coordinate system changes?
Best Regards,
Brent Fraser
On 7/13/2012 9:27 AM, Joshua Meyer wrote:
> My data is not being projected in the correct location.  However,
> Feature_Report is no longer working correctly.  The parcels are no
> longer showing in the report after using the identify tool.  All the
> information I am wanting is displaying currently but the parcel image is
not present.
> 107 S. 11th Street
> Lexington Mo, 64067
> From: geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Joshua
> Meyer
> Sent: Thursday, July 12, 2012 10:21 AM
> To: 'Brent Fraser'
> Thank you very much!  That fixed it!
> Joshua Meyer
> Sent: Thursday, July 12, 2012 10:04 AM
> To: Joshua Meyer
> Joshua,
>       From your posts, I assume you want to display the data in
> EPSG:3857 to allow overlaying your data on to Google/Bing/Yahoo map
> layers?  And your data is currently stored in
> NAD_1983_StatePlane_Missouri_West_FIPS_2403_
> **Feet** which (according to SpatialReference) is not defined by EPSG,
> but is defined by ESRI.
> EPSG does define the State Plane zone with units of meters,
> EPSG:26998, but that won't help.
> So the only part of the configuration that needs to define the State
> plane zone is in the LAYER's PROJECTION object (it specifies the
> coordinate system of the source data).  The MAP's PROJECTION object
> needs to define the target coordinate system (EPSG:3857) as mapserver
> will handle the re-projection from the source system to the target
> system.  And the GeoMoose needs only to be configured for EPSG:3857
> since there is no need for it to know about the coordinate system of the
source data.
> In your Mapserver map file, the LAYER should have
> LAYER
>       PROJECTION
>           'init=esri:102698'
>       END
> (note the esri, not epsg as the defining authority).  And the MAP
> object should have
> MAP
>       PROJECTION
>           'init=epsg:3857'
>       END
> Best Regards,
> Brent Fraser
> On 7/12/2012 8:30 AM, Joshua Meyer wrote:
>> I may not totally understand your question.  Here is the Projection
>> from one of the map files.
>> 	WEB
>> 		METADATA
>> 			'ows_title' 'County'
>> 			'ows_srs' 'EPSG:102698 EPSG:26998 EPSG:26915
>> EPSG:4326 EPSG:900913 EPSG:3857'
>> 			'ows_enable_request' '*'
>> 		END
>> 	END
>> 	PROJECTION
>> 		'init=epsg:26998'
>> 	END
>> I have added the projection to the geomoose.html file.
>> 	<script type="text/javascript"
>> src="projections/EPSG26998.js"></script>
>> Here is the projection file as I copied off of spatialreference.
>> 	Proj4js.defs["EPSG:26998"] = "+proj=tmerc +lat_0=36.16666666666666
>> +lon_0=-94.5 +k=0.999941177 +x_0=850000 +y_0=0 +ellps=GRS80
>> ++datum=NAD83 units=m +no_defs";
>> 107 S. 11th Street
>> Lexington Mo, 64067
>> Sent: Thursday, July 12, 2012 9:18 AM
>> To: Joshua Meyer
>> So what does your Mapserver mapfile contain in terms of projections?
>> Best Regards,
>> Brent Fraser
>> On 7/12/2012 8:08 AM, Joshua Meyer wrote:
>>> I have performed all those steps.  If I leave the projection in
>>> mapbook.xml as 3857 my data is projected off the coast of Maine and
>> rotated clockwise.
>>> The map files I created(modified) are initialized as 26998.  The
>>> settings.ini and mapbook.xml are both 3857. I have changed the
>>> projection in settings.ini to 26998 and this has no effect on how my
>>> data
>> is projected.
>>> Joshua Meyer
>>> From: TC Haddad [mailto:tchaddad at gmail.com]
>>> Sent: Tuesday, July 10, 2012 3:56 PM
>>> To: Joshua Meyer
>>> Make sure to look closely at:
>>> http://www.geomoose.org/docs/projections.html
>>> In particular, both parts of Step 2.
>>> Tanya
>>> On Tue, Jul 10, 2012 at 12:03 PM, Joshua Meyer
>>> <jmeyer at lcsheriff.com>
>> wrote:
>>>> I am new to GeoMoose.  I have added my data and have it projecting.
>>>> The data is all NAD_1983_StatePlane_Missouri_West_FIPS_2403_Feet.
>>>> I looked up the information on spatialreference.com and found I
>>>> needed EPSG:26998.  I added the new EPSG as per the GeoMoose
>>>> instructions on http://www.geomoose.org/docs/projections.html.
>>>> My data is being projected over Africa.  Does anyone know what I am
>>>> doing wrong?
>>>> Thanks,
>>>> Josh
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
