[Geomoose-users] Authentication in GM 2.6?
Bistrais, Bob Bob.Bistrais at maine.gov
Tue Jul 24 07:49:25 PDT 2012
Yes, we do have LDAP.  Also, I think it will be necessary to get the username from Apache.  I've tried the $_SERVER['PHP_AUTH_USER'], but it doesn't seem to work.
Can you point to any documentation on the Apache authentication modules?
Sent: Tuesday, July 24, 2012 10:41 AM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Authentication in GM 2.6?
The easy thing to do is use one of the authentication/authorization modules that comes with apache.  Also, keep in mind that generally you should run authenticated services over https instead of http.  What you end up doing depends on how many users you expect and if you already have authentication infrastructure (e.g. LDAP).
On Jul 24, 2012, at 9:04 AM, Bistrais, Bob wrote:
I did a little searching on this, but not sure where to start.  I will be building an application in the near future which will require restricted access.  Can anyone offer advice or point me to reference sources?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120724/f24dcd63/attachment.html>
More information about the Geomoose-users mailing list
