[Geomoose-users] first impressions
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Jun 8 07:31:32 PDT 2012
Thanks for the prompt reply Jim.
It's good to see that more releases is something being considered. I like
the notion of "Release Early, Release Often" as a development methodology.
> Of course, since GeoMoose is open source, you are more than welcome to
submit a bug fix and if it is a big enough issue, we'd release a point
release for it (or wait and bundle a few fixes together).
I don't submit bug fixes myself typically but I'm very good at spotting
bugs which is why I like to check out a projects bugs list; it's also a
good way to seeing the health of a project. Not everyone's skills are best
used at programming (although I do actually know PHP, but obviously not
this code-base).
Jonathan
On 8 June 2012 15:03, Jim Klassen <klassen.js at gmail.com> wrote:
> On Jun 8, 2012, at 6:12 AM, Jonathan Moules wrote:
> Hi,
> I'm investigating Web-mapping frameworks for a project and came across
> GeoMoose which has a nice name and looks cool.
> Unfortunately I have some concerns:
> a) I can't for the life of me find a bug tracker. To graduate from the OGC
> you must have one somewhere but its very well hidden. Usually this is on
> the home page with a big "report bugs" button There's absolutely nothing on
> the wiki for bug reporting either..
> http://trac.osgeo.org/geomoose
> b) Looking at the web-page (geomoose.org), its clear that many parts of
> the web-site are out of date or simply not working. There's no obvious way
> to contact the project from there - it took several minutes of googling to
> find the subscription to this mailing list. This page -
> http://geomoose.org/info/mailing_lists.html - points to a 404. The wiki
> points to a different page -
> http://geomoose.org/wiki/index.php/Mailing_Lists - that also is a 404. :-S
> A nice big obvious link somewhere on the home page should help get more
> people into the community.
> Agreed. We are in a bit of a state of flux right now as we transition
> from 2.4 to 2.6 and I suspect most of the website updates are happening in
> the 2.6 right now. This should be cleaned up at the end of next week when
> 2.6 is scheduled to be released.
> For now the most recent site is at:
> http://www.geomoose.org/trunk
> c) On a practical level, I'm concerned by the release schedule of
> GeoMOOSE; namely there don't seem to have been any point releases (aka, bug
> fixes) since 2.0.1. They're all major point releases which are about a
> year+ apart. That's a long time to wait for a bug-fix (I'm aware there are
> nightlies, but obviously you don't use them on production).
> Also agreed. This has been addressed by the PSC and there will be a 2.4.1
> released about the same time as 2.6. Also, 2.4 is more or less a point
> release to 2.2. Of course, since GeoMoose is open source, you are more
> than welcome to submit a bug fix and if it is a big enough issue, we'd
> release a point release for it (or wait and bundle a few fixes together).
> There a lots of little things too, but as I don't want my first post to
> the mailing list to be too negative, I'll stop here. :-)
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120608/21515ba0/attachment-0001.html>
More information about the Geomoose-users
