[Geomoose-users] Identify a Layer
Bistrais, Bob Bob.Bistrais at maine.gov
Wed Mar 21 11:40:00 EDT 2012
Without seeing your code, of course, it's anyone's guess. But here's a
few things to look for:
The .map file for any layer you want to Identify should have a line in
the metadata section:
"identify_record" "select_mylayer.html"	--substitute your layer name for
mylayer
You should also name the fields you want to identify, also in the
metadata section:
"fields" "(list of the fields, separated by commas)"
Is the layer you are identifying visible?  By default, layers not
visible (either turned off, or not within scale range) will not
Identify.
The identify html file should have a format like this, for each item you
want to show:
<td align="left" valign="top"><b>Name:</b></td>
<td>[NAME]</td>
</tr>
Finally, are you testing with FireFox with the Firebug extension?  This
is a useful tool to diagnose your application.
-Bob
-----Original Message-----
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Zery
Sent: Wednesday, March 21, 2012 11:05 AM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Identify a Layer
I've searched the archive and had read the document, and I will be
hanging around here oftenly so please bear with me.
What I am doing right now with GeoMoose demo 2.2 is just changing here
and there but I am not messing with any codes besides mapbook.xml, etc.
My issue right now is when I click on a layer using identify tool I
can't get any result on the Information tabs.
I have change some pointers in identify_parcel.html that I'm guessing it
should be an attribute title of the layer. I also had add/copy metadata
from original parcels mapfile into my mapfile. I'm not messing with
identify.php.
As an info, my map consists of a few mapfile that was reading only
shapefiles, no google, bing or any other WMS services.
So, is there any configuration that i had missed to make my identify
works?
Reagards,
Zery
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
