[Geomoose-users] Identify tool - How to?
Zery zery.sp at gmail.com
Tue Mar 27 18:07:17 EDT 2012
I have the same issue before, first thing i would asked to you is :
(this is my stupid mistake) are your identify template file
"identify_placenames.html" in the same folder with your  mapfile?
Then, make sure there is no missed typed names, attribute column, etc.
Regards,
Zery
On 3/28/2012 12:04 AM, neslonotnilc wrote:
> I have been troubleshooting the identify feature for my geomoose application.
> I can get some of the layers to identify, and other layers won't show up
> when I try to identify them.  I have looked on geomoose.org for a How To for
> the identify tool so I could make sure I was doing everything required for
> my mapfile, mapbook.xml, and my template but there doesn't seem to be one.
> Where can I go to get more information on this feature?  I think if I can
> get some pointers on what I need to do then I can make all the other layers
> be identifiable.
> This is one of the layers that will not identify.  I have a layer named
> placenames.  In the mapbook.xml I have it referenced as:
> ESRI:102743
> <map-source name="placenames" type="mapserver" reference="true">
> <file>./interactive_maps/placenames/placenames.map</file>
> <layer name="placenames"/>
> </map-source>
> <layer title="Place Names" src="placenames/placenames" status="on"
> popups="false" minscale="0" maxscale="150000" metadata="false">
> </layer>
> ---Mapfile ---
> MAP
> NAME 'placenames'
> SIZE 800 650
> STATUS ON
> EXTENT  1426801 6519737 2267577 7175357
> UNITS FEET
> #FONTSET '../fonts/fontset.list'
> #SYMBOLSET '../symbols/symbol.sym'
> TRANSPARENT TRUE
> IMAGETYPE PNG
> INCLUDE "../../geomoose_globals.map"
> WEB
> INCLUDE "../../temp_directory.map"
> END
> PROJECTION
> 'init=esri:102743'
> end
> LEGEND
> STATUS ON
> END
> LAYER
> NAME "placenames"
> DATA "placenames.shp"
> STATUS DEFAULT
> TYPE POINT
> LABELITEM 'NAME'
> LABELCACHE ON
> LABELMAXSCALE 100000
> PROJECTION
> 'init=esri:102743'
> end
> CLASS
> NAME 'Attractions'
> STYLE
> SYMBOL 'STAR'
> COLOR 255 102 51
> OUTLINECOLOR 0 0 0
> SIZE 8
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans-bold
> SIZE 8
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 254 254 254
> BUFFER 4
> PARTIALS FALSE
> POSITION auto
> SIZE 7
> END
> END
> METADATA
> 'identify_record' 'identify_placenames.html'
> END
> END
> END
> ---Identify results---
> <results><script/><html></html></results>
> View this message in context: http://geomoose-users.964460.n3.nabble.com/Identify-tool-How-to-tp3861865p3861865.html
> Sent from the Geomoose-users mailing list archive at Nabble.com.
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
