[Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
Dan Little danlittle at yahoo.com
Wed May 23 13:15:03 EDT 2012
Wouldn't it be easier to simply check if a value is set?
IE:
if($field3 == "HOUSE" and isset($searval3) and $searchval3 != "") {
 ... add the clause
That way you don't have an extra SQL bits. The extraneous "OR"s would just serve to confuse the database.
>________________________________
> From: Jim Dahl <jim.dahl at mail.co.douglas.mn.us>
>To: "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>Sent: Wednesday, May 23, 2012 8:40 AM
>Subject: [Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
>I have need to search on multiple fields and the following code works if I have a wildcard in all of the fields.  If I take out a wildcard and do not enter anything in that field, the result is nothing found.  Probably because the empty field doesn’t match the database for any entries.  So what I would like to do is Make and OR with the field without a wild card and the other fields that have the AND.  Hope this makes sense to someone.  I credit Dan with the code for the implode clauses and it works great with the criteria of wild cards or have a pull down in the field that contains all the possible entries.  HNUM is the field I would like to not have the wildcard.  I have as many as ten fields, but show fewer for this example.  THANKS.
>$clauses = array();
>if($field3 == "HNUM") {
>array_push($clauses, "HNUM like '".$searchval3."'");
>if($field4 == "STREET") {
>array_push($clauses, "STREET like '%".$searchval4."%'");
>if($field5 == "CITY") {
>array_push($clauses, "CITY like '%".$searchval5."%'");
>$all_clauses = implode(" AND ", $clauses);
>$rs = $conn->Execute("SELECT * FROM housenum WHERE ".$all_clauses." ORDER BY ".$sort." ASC");
>Jim Dahl, GISP
>GIS Coordinator
>Douglas County Public Works
>526 Willow Dr
>PO Box 398
>Alexandria MN 56308
>V 320-762-2933
>   320-762-2999
>F 320-762-2998
>_______________________________________________
>Geomoose-users mailing list
>Geomoose-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120523/fb04ba36/attachment.html
More information about the Geomoose-users mailing list
