[Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Wed May 23 13:53:17 EDT 2012
Dan, I am not sure what the isset does and the != “” must be saying to ignore the field if there are no entries?  Anyway, I get no results on any searches
if($field3 == "HNUM" and isset($searchval3) and $searchval3 != "") {
array_push($clauses, "HNUM like '".$searchval3."'");
Sent: Wednesday, May 23, 2012 12:15 PM
To: Jim Dahl; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
Wouldn't it be easier to simply check if a value is set?
IE:
if($field3 == "HOUSE" and isset($searval3) and $searchval3 != "") {
 ... add the clause
That way you don't have an extra SQL bits. The extraneous "OR"s would just serve to confuse the database.
From: Jim Dahl <jim.dahl at mail.co.douglas.mn.us<mailto:jim.dahl at mail.co.douglas.mn.us>>
To: "geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>" <geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>>
Sent: Wednesday, May 23, 2012 8:40 AM
Subject: [Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
I have need to search on multiple fields and the following code works if I have a wildcard in all of the fields.  If I take out a wildcard and do not enter anything in that field, the result is nothing found.  Probably because the empty field doesn’t match the database for any entries.  So what I would like to do is Make and OR with the field without a wild card and the other fields that have the AND.  Hope this makes sense to someone.  I credit Dan with the code for the implode clauses and it works great with the criteria of wild cards or have a pull down in the field that contains all the possible entries.  HNUM is the field I would like to not have the wildcard.  I have as many as ten fields, but show fewer for this example.  THANKS.
$clauses = array();
if($field3 == "HNUM") {
if($field4 == "STREET") {
array_push($clauses, "STREET like '%".$searchval4."%'");
if($field5 == "CITY") {
array_push($clauses, "CITY like '%".$searchval5."%'");
$all_clauses = implode(" AND ", $clauses);
$rs = $conn->Execute("SELECT * FROM housenum WHERE ".$all_clauses." ORDER BY ".$sort." ASC");
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
526 Willow Dr
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-762-2999
F 320-762-2998
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20120523/7dd64e0d/attachment-0001.html
More information about the Geomoose-users mailing list
