[Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
Eli Adam eadam at co.lincoln.or.us
Wed May 23 14:06:44 EDT 2012
> I have need to search on multiple fields and the following code works if I
> have a wildcard in all of the fields.  If I take out a wildcard and do not
> enter anything in that field, the result is nothing found.  Probably because
> the empty field doesn’t match the database for any entries.  So what I would
Is this a case where blanks[0..n] can be used?
http://geomoose.org/trunk/services/query.php.html?highlight=blanks
Eli
More information about the Geomoose-users mailing list
