[Geomoose-users] GeoMoose Search on Multi Fields with Implode
	Clause
    Jim Dahl
    jim.dahl at mail.co.douglas.mn.us
    Wed May 23 14:44:02 EDT 2012
Thanks Eli, I will have to look into this one.  It appears that the operator can select whether they want EXACT or Partial matches.  Maybe later in week. Thanks for the info!
Jim
-----Original Message-----
Sent: Wednesday, May 23, 2012 1:07 PM
To: Jim Dahl
Cc: Dan Little; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] GeoMoose Search on Multi Fields with Implode Clause
> I have need to search on multiple fields and the following code works
> if I have a wildcard in all of the fields.  If I take out a wildcard
> and do not enter anything in that field, the result is nothing found.
> Probably because the empty field doesn't match the database for any
> entries.  So what I would
Is this a case where blanks[0..n] can be used?
http://geomoose.org/trunk/services/query.php.html?highlight=blanks
Eli
More information about the Geomoose-users
