[Geomoose-users] Identify tool
Eli Adam
eadam at co.lincoln.or.us
Wed Nov 14 10:14:39 PST 2012
On Wed, Nov 14, 2012 at 10:12 AM, Anderson, Dean <
anderson.dean at co.polk.or.us> wrote:
> I think the "TEMPLATE O" is misstyped and should probably be "TOLERANCE
> 0". At least that would make it more consistent with the demo.
Might want to try TOLERANCE 20 too.
Eli
> Dean
> On Wed, Nov 14, 2012 at 10:07 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>> On Wed, Nov 14, 2012 at 2:50 AM, moff mofire <githiro at gmail.com> wrote:
>>> Thank you very much Anderson for your reply. Please find attached my
>>> mapfile and identify.html.
>> Moff,
>> Does you layer display properly?
>> I'm not sure that you need "TEMPLATE O" in your map file.
>> Sometimes PostGIS connections can work better more like (copied from,
>> http://www.mapserver.org/input/vector/postgis.html):
>> DATA "the_geom from the_database using unique gid using srid=4326"
>> Eli
>>> Also this how i have called the layer on mapbook;
>>> <map-source name="county" type="mapserver">
>>> <file>./demo/parcels/parcels.map</file>
>>> <layer name="county" status="on"/>
>>> <param name="FORMAT" value="image/png;bits=8"/>
>>> </map-source>
>>> <catalog>
>>> <group title="Base Layers">
>>> <layer title="County" src="county/county" legend="true"
>>> tip="County layer" show-legend="true" fade="false" unfade="false"/>
>>> </group>
>>> </catalog>
>>> On Wed, Nov 14, 2012 at 12:42 AM, Anderson, Dean <
>>>> Please send the mapfile for your identify as an attachment and where
>>>> you call the mapfile from your mapbook.xml.
>>>> Thanks
>>>> Dean
>>>> On Tue, Nov 13, 2012 at 1:01 PM, moff mofire <githiro at gmail.com> wrote:
>>>>> Please someone help me solve this problem !
>>>>> Error Calling the server:
>>>>> TypeError: Application.getMapSource(
>>>>> layerName) is undefined
>>>>> This error appears when i try to use the identify or select tool on a
>>>>> postgis layer.
>>>>> I would appreciate any assistance.
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Dean R Anderson
>>>> IT Director
>>>> Polk County
> Dean R Anderson
> IT Director
> Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121114/fc565aee/attachment.html>
More information about the Geomoose-users
