[Geomoose-users] Identify tool
moff mofire
githiro at gmail.com
Wed Nov 14 21:48:55 PST 2012
Thank you very much guys for your help. But my problem is still there, I
have tried to change the tolerance and also add the "the_geom FROM county
using unique oid using srid=4326 " but still no change. I have even tried
to rename the postgis table columns but no change. The layer is displaying
perfectly. find attached the altered mapfile and identify.html
I am so frustrated and i want to use this application for my masters degree
project.
On Wed, Nov 14, 2012 at 9:14 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> On Wed, Nov 14, 2012 at 10:12 AM, Anderson, Dean <
> anderson.dean at co.polk.or.us> wrote:
>> I think the "TEMPLATE O" is misstyped and should probably be "TOLERANCE
>> 0". At least that would make it more consistent with the demo.
> Might want to try TOLERANCE 20 too.
> Eli
>> Dean
>> On Wed, Nov 14, 2012 at 10:07 AM, Eli Adam <eadam at co.lincoln.or.us>wrote:
>>> On Wed, Nov 14, 2012 at 2:50 AM, moff mofire <githiro at gmail.com> wrote:
>>>> Thank you very much Anderson for your reply. Please find attached my
>>>> mapfile and identify.html.
>>> Moff,
>>> Does you layer display properly?
>>> I'm not sure that you need "TEMPLATE O" in your map file.
>>> Sometimes PostGIS connections can work better more like (copied from,
>>> http://www.mapserver.org/input/vector/postgis.html):
>>> DATA "the_geom from the_database using unique gid using srid=4326"
>>> Eli
>>>> Also this how i have called the layer on mapbook;
>>>> <map-source name="county" type="mapserver">
>>>> <file>./demo/parcels/parcels.map</file>
>>>> <layer name="county" status="on"/>
>>>> <param name="FORMAT" value="image/png;bits=8"/>
>>>> </map-source>
>>>> <catalog>
>>>> <group title="Base Layers">
>>>> <layer title="County" src="county/county" legend="true"
>>>> tip="County layer" show-legend="true" fade="false" unfade="false"/>
>>>> </group>
>>>> </catalog>
>>>> On Wed, Nov 14, 2012 at 12:42 AM, Anderson, Dean <
>>>>> Please send the mapfile for your identify as an attachment and where
>>>>> you call the mapfile from your mapbook.xml.
>>>>> Thanks
>>>>> Dean
>>>>> On Tue, Nov 13, 2012 at 1:01 PM, moff mofire <githiro at gmail.com>wrote:
>>>>>> Please someone help me solve this problem !
>>>>>> Error Calling the server:
>>>>>> TypeError: Application.getMapSource(
>>>>>> layerName) is undefined
>>>>>> This error appears when i try to use the identify or select tool on a
>>>>>> postgis layer.
>>>>>> I would appreciate any assistance.
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>>> Dean R Anderson
>>>>> IT Director
>>>>> Polk County
>> Dean R Anderson
>> IT Director
>> Polk County
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121115/d18d93e5/attachment.html>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121115/d18d93e5/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121115/d18d93e5/attachment.obj>
More information about the Geomoose-users
