[Geomoose-users] Identify tool
moff mofire githiro at gmail.com
Thu Nov 15 07:01:59 PST 2012
yes its 4326.
I have managed to get rid of the error that was popping out, but now when i
click on the layer using the identify tool i only get the coordinates.
I guess my mapbook had some errors i had to go through it line by line
comparing with the original mapbook.
Any help????
On Thu, Nov 15, 2012 at 5:47 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
>  What is your display coordinate system? 4326?
> Best Regards,
> Brent Fraser
> On 11/14/2012 10:48 PM, moff mofire wrote:
> Thank you very much guys for your help. But my problem is still there, I
> have tried to change the tolerance and also add the "the_geom FROM county
> using unique oid using srid=4326 " but still no change. I have even tried
> to rename the postgis table columns but no change. The layer is displaying
> perfectly. find attached the altered mapfile and identify.html
> I am so frustrated and i want to use this application for my masters
> degree project.
> On Wed, Nov 14, 2012 at 9:14 PM, Eli Adam <eadam at co.lincoln.or.us> wrote:
>>  On Wed, Nov 14, 2012 at 10:12 AM, Anderson, Dean <
>> anderson.dean at co.polk.or.us> wrote:
>>> I think the "TEMPLATE O" is misstyped and should probably be "TOLERANCE
>>> 0". At least that would make it more consistent with the demo.
>> Might want to try TOLERANCE 20 too.
>> Eli
>>> Dean
>>>  On Wed, Nov 14, 2012 at 10:07 AM, Eli Adam <eadam at co.lincoln.or.us>wrote:
>>>>  On Wed, Nov 14, 2012 at 2:50 AM, moff mofire <githiro at gmail.com>wrote:
>>>>> Thank you very much Anderson for your reply. Please find attached my
>>>>> mapfile and identify.html.
>>>> Moff,
>>>> Does you layer display properly?
>>>> I'm not sure that you need "TEMPLATE O" in your map file.
>>>> Sometimes PostGIS connections can work better more like (copied from,
>>>> http://www.mapserver.org/input/vector/postgis.html):
>>>> DATA "the_geom from the_database using unique gid using srid=4326"
>>>> Eli
>>>>>  Also this how i have called the layer on mapbook;
>>>>> <map-source name="county" type="mapserver">
>>>>>         <file>./demo/parcels/parcels.map</file>
>>>>>         <layer name="county" status="on"/>
>>>>>         <param name="FORMAT" value="image/png;bits=8"/>
>>>>>     </map-source>
>>>>> <catalog>
>>>>>         <group title="Base Layers">
>>>>>             <layer title="County" src="county/county"  legend="true"
>>>>> tip="County layer" show-legend="true" fade="false" unfade="false"/>
>>>>>         </group>
>>>>>     </catalog>
>>>>> On Wed, Nov 14, 2012 at 12:42 AM, Anderson, Dean <
>>>>>> Please send the mapfile for your identify as an attachment and where
>>>>>> you call the mapfile from your mapbook.xml.
>>>>>>  Thanks
>>>>>>  Dean
>>>>>>   On Tue, Nov 13, 2012 at 1:01 PM, moff mofire <githiro at gmail.com>wrote:
>>>>>>>  Please someone help me solve this problem !
>>>>>>> Error Calling the server:
>>>>>>> TypeError: Application.getMapSource(
>>>>>>> layerName) is undefined
>>>>>>> This error appears when i try to use the identify or select tool on
>>>>>>> a postgis layer.
>>>>>>> I would appreciate any assistance.
>>>>>>>  _______________________________________________
>>>>>>> Geomoose-users mailing list
>>>>>>> Geomoose-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>>>> Dean R Anderson
>>>>>> IT Director
>>>>>> Polk County
>>> Dean R Anderson
>>> IT Director
>>> Polk County
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121115/9c30b6c5/attachment.html>
More information about the Geomoose-users mailing list
