[Geomoose-users] multiple applications from same GeoMoose code
Paul Wickman paul at flatrockgeo.com
Fri Nov 30 09:06:19 PST 2012
We have done a single code base/multiple mapbooks with all our v2.4
installs; modifying settings.in and the client-specific index.php files.
Just doing basic Apache auth for those index files, but it would be great
to have that ability baked more directly into GM.
Paul Wickman
CTO | Flat Rock Geographics
612.280.5850 | paul at flatrockgeo.com
www.flatrockgeo.com | twitter.com/flatrockgeo
On Nov 30, 2012, at 10:38 AM, Brian Fischer <bfischer at houstoneng.com> wrote:
  I was just curious if anyone else has thought about or tried any other
methods to use multiple mapbooks and settings.ini files with one GeoMoose
code folder.
In the past I have used this method and it works well.
http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books
With GeoMoose 2.6 there is another file that is introduced for
local_settings.ini.
Also is anyone working on some type of authentication module for GeoMoose.
Basically what I’m thinking is depending on who you login as it would
configure the catalog differently.
Just wanted to get a thread started if anyone else has worked on this or
thinking about it.
*Brian Fischer, CFM***
Principal | GIS Project Manager
*O* 763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
<image001.jpg>
  6901 E Fish Lake Rd. , Suite 140 • Maple Grove, MN • 55369
*www.houstoneng.com* <http://www.houstoneng.com/>* ***
This entire message (including all forwards and replies) and any
attachments are for the sole use of the intended recipient(s) and may
contain proprietary, confidential, trade secret, work-product,
attorney-client or privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited and may be a violation of law. If
you are not the intended recipient, please contact the sender by reply
email and destroy all copies of the original message.
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20121130/e373d9ca/attachment-0001.html>
More information about the Geomoose-users mailing list
