[Geomoose-users] multiple applications from same GeoMoose code
giswerk at gis-ma.org
Fri Nov 30 09:22:25 PST 2012
du to the fact that I want to deliver user specific analysis results
on a daily base (local avalanche risk calculations) I use a very
straightforward workaround:
1) ask user to register (simple form with lightweight database)
2) generate for the specific session a user_SessionID of the type
(as an example: pan271112_107111_472245)
3) using the user_SessionID a python based analysis script is running
on the server (dealing with the calculations etc.) that finally
generates <user_SessionID_geomoose.html> <user_SessionID_settings.ini>
and <userIDmapbook.xml> and redirects the corresponding user to his
"personal" geomoose session
I know about the conceptual, security and performance shortcomings -
but nevertheless it works....
At least for this kind of use cases I would really appreciate the
integration of personalized sessions. If possible I would also
contribute in any way...
best regards Chris
Zitat von Paul Wickman <paul at flatrockgeo.com>:
> We have done a single code base/multiple mapbooks with all our v2.4
> installs; modifying settings.in and the client-specific index.php files.
> Just doing basic Apache auth for those index files, but it would be great
> to have that ability baked more directly into GM.
> Paul Wickman
> CTO | Flat Rock Geographics
> 612.280.5850 | paul at flatrockgeo.com
> www.flatrockgeo.com | twitter.com/flatrockgeo
> On Nov 30, 2012, at 10:38 AM, Brian Fischer <bfischer at houstoneng.com> wrote:
> I was just curious if anyone else has thought about or tried any other
> methods to use multiple mapbooks and settings.ini files with one GeoMoose
> code folder.
> In the past I have used this method and it works well.
> http://www.geomoose.org/wiki/index.php/Modification_to_Use_Multiple_Map_Books
> With GeoMoose 2.6 there is another file that is introduced for
> local_settings.ini.
> Also is anyone working on some type of authentication module for GeoMoose.
> Basically what I'm thinking is depending on who you login as it would
> configure the catalog differently.
> Just wanted to get a thread started if anyone else has worked on this or
> thinking about it.
> *Brian Fischer, CFM***
> Principal | GIS Project Manager
> *O* 763.493.4522 | *D* 763.493.6664 | *M* 763.229.2734
> <image001.jpg>
> 6901 E Fish Lake Rd. , Suite 140 o Maple Grove, MN o 55369
> *www.houstoneng.com* <http://www.houstoneng.com/>* ***
> This entire message (including all forwards and replies) and any
> attachments are for the sole use of the intended recipient(s) and may
> contain proprietary, confidential, trade secret, work-product,
> attorney-client or privileged information. Any unauthorized review, use,
> disclosure or distribution is prohibited and may be a violation of law. If
> you are not the intended recipient, please contact the sender by reply
> email and destroy all copies of the original message.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
