[Geomoose-users] Trouble with query using file GDB
Eli Adam eadam at co.lincoln.or.us
Tue Sep 25 18:28:32 PDT 2012
Bob,
On Mon, Sep 24, 2012 at 10:19 AM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> I am working on switching my parcel data from shapefile to file GDB for a
> parcel viewer application.  I have been able to get the data to display, and
> I can also do an Identify with this layer.  But, I am not able to use the
> Search feature and get results.  The response is “No results found for your
> query”.  Using a shapefile with the same query parameters does work.  Is
> there some parameter in the map file, perhaps, that needs to be set?  Some
> other setting?
Looking into unique fields may help, here is an old thread which has
some similarities.
http://lists.osgeo.org/pipermail/geomoose-users/2011-November/003481.html
Bests, Eli
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
