[Geomoose-users] Trouble creating PDF templates
Mark Volz MarkVolz at co.lyon.mn.us
Thu Aug 8 14:06:32 PDT 2013
Hello,
In the past I think I had success using primo pdf to create the template.  However that was a while ago so things could have changed...
Lyon County, MN
(507) 532-8218
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Eli Adam
Sent: Thursday, August 08, 2013 3:25 PM
To: Bistrais, Bob
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Trouble creating PDF templates
On Thu, Aug 8, 2013 at 12:50 PM, Bistrais, Bob <Bob.Bistrais at maine.gov<mailto:Bob.Bistrais at maine.gov>> wrote:
I'm trying to modify the default PDF printing templates for GM 2.6.1, adding my own agency logo.  I do the process by making a copy of the template into Word, make the modifications, them use Word's Save As Adobe PDF function to save it back as a PDF file.
When I attempt to use it, I find an error in Firebug:
<b>FPDF error:</b> Unable to find xref table.
This sounds like an error from the underlying pdf library.  It seems that your pdf has some feature that is not supported by fpdf.  Try taking the pdf you made and running it through a pdf printer or otherwise converting it to pdf with a different method.
HTH, Eli
I've followed the GM documentation and think I was doing it correctly.  Suggestions?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130808/ff020bca/attachment.html>
More information about the Geomoose-users mailing list
