[Geomoose-users] Trouble creating PDF templates
Eli Adam eadam at co.lincoln.or.us
Thu Aug 8 13:25:05 PDT 2013
On Thu, Aug 8, 2013 at 12:50 PM, Bistrais, Bob <Bob.Bistrais at maine.gov>wrote:
>  I’m trying to modify the default PDF printing templates for GM 2.6.1,
> adding my own agency logo.  I do the process by making a copy of the
> template into Word, make the modifications, them use Word’s Save As Adobe
> PDF function to save it back as a PDF file. ****
> When I attempt to use it, I find an error in Firebug:****
> <b>FPDF error:</b> Unable to find xref table.
This sounds like an error from the underlying pdf library.  It seems that
your pdf has some feature that is not supported by fpdf.  Try taking the
pdf you made and running it through a pdf printer or otherwise converting
it to pdf with a different method.
HTH, Eli
> I’ve followed the GM documentation and think I was doing it correctly.
> Suggestions?****
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130808/14aef7c7/attachment.html>
More information about the Geomoose-users mailing list
