[Geomoose-users] Some layers print, some don't
James Klassen klassen.js at gmail.com
Fri Aug 9 09:51:02 PDT 2013
Is this something that should be clarified in the docs?
On 2013/8/9 8:56 AM, Bistrais, Bob wrote:
> With a shout-out to Mark for his help, I have this issue resolved.
> Turned out it was the server name in the ini file.  Localhost worked
> on the development machines, but I needed the server name for the test
> server (and I imagine the production server when the time comes).
> *From:*Jim Klassen [mailto:klassen.js at gmail.com]
> *Sent:* Thursday, August 08, 2013 5:47 PM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Some layers print, some don't
> You might be on the right track w.r.t. to looking a temp directory issue.
> On Aug 6, 2013, at 11:45 AM, Bistrais, Bob wrote:
> The saga of my printing woes continues.  I got the printing to work
> correctly with my application, consuming some of the WMS services as
> MapServer services to avoid timeout when printing.  This works well on
> my development machine.  But when I transferred the code over to a
> test machine, I find that the layers display in the browser just fine,
> but only the remaining "pure" WMS services appear in the print
> output.  To make it even more confusing, I moved the code to my
> "sandbox" machine, configuration pretty much identical to the test
> server, and everything works fine.   Is there an output location
> setting that I could have missed?  Something else?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130809/0df5c5ac/attachment.html>
More information about the Geomoose-users mailing list
